MSM usage
June 11, 2010 1:44pm
  • #1 / Jun 11, 2010 1:44pm
    AndyGt
    We are looking into getting MSM 2.0 but I wanted to check one item first. The sites are on the same server but have separate IP addresses due to SSL certificates being used.
    I just wanted to make sure we could still use MSM in this instance.
    Also as a followup question, can the System folder be outside the web root folder (for extra security) of the main site and still be accessed?
    Many thanks
    Andy
  • #2 / Jun 11, 2010 1:48pm
    Hi, Andy -
    As long as each sub-site can access the main site’s system directory, then this will work.
    Yes the system folder can be outside the web root.  See running the system above web-root.  That is for EE 2.
    Does that help?
  • #3 / Jun 11, 2010 2:00pm
    AndyGt
    Hi Lisa,
    With regards the system folder, yes I know it can be (this is how we have it installed now). Was just curious if the other sites on that server could access a hidden system folder.
    Also, the question of the MSM with separate IP addresses but on same server still stands.
  • #4 / Jun 11, 2010 2:02pm
    They should be able to; this is really up to how your hosting is configured.  In EE 2 you’ll just set up the index.php appropriately for each site, including the path to the system folder, above web-root or otherwise.
    As far as different IP addresses, that should not matter - the primary issue is making sure all Sites can access the system folder.
  • #5 / Jun 11, 2010 2:04pm
    AndyGt
    Thanks Lisa,
    Should be ordering this month then.I guess worst case scenario is we can use the MSM for other sites down the road if we have trouble.
    I see many more EE sites in our future 😉
    Cheers
    Andy
  • #6 / Jun 11, 2010 2:06pm
    Glad to help, Andy!
