MT Export - comments issue [solved], partial exporting [not solved]
June 01, 2010 1:57am
  • #1 / Jun 01, 2010 1:57am
    Adam Lasnik
    Hi there,
    I’m trying to carefully follow the instructions here:
    http://expressionengine.com/wiki/Export_Entries/
    ...and it looks like the entries are being exported just fine… but no comments.
    I used the same weblog name for both (weblog1) and also tried just “weblog” for the comments form.  I’ve select php on input for the comments template, just as instructed.
    Any other troubleshooting ideas?  Thanks!
    P.S.—I verified that php is being parsed in the comments template by adding an “echo” and seeing that included in the export.
    EDITED TO ADD:  Ah ha!  I saw the EE2.0 template versions listed in a comment of that page.  That got things working 😊  Well, sort of.  I can’t export all 600+ posts+comments without running out of memory on my host… so I should probably do 50 posts+comments at a time.
    I know how to do a limit=50, but can you kindly let me know how I can do 1-50, then 51-100, etc?  Thanks! 😊
  • #2 / Jun 01, 2010 4:08am
    I’m glad you solved that one, Adam 😊 Please post again as needed.
