Validation Error
May 31, 2010 10:21am
  • #1 / May 31, 2010 10:21am
    Greg8033
    I’m getting an validation error on this page.
    http://517design.com/NewCreations.php?/webDesign/
    http://validator.w3.org/
  • #2 / May 31, 2010 10:31am
    Greg8033, this has nothing to do with EE. It has to do with you using id=“webDesign” twice on the page.
  • #3 / May 31, 2010 10:50am
    Greg8033
    Ok let me ask this….
    I am currently using this for my menu bar;
    <body {if embed:body_id} id="{embed:body_id}"
    {if:elseif segment_1} id="{segment_1}"
    {if:else} id="home" {/if} class="screen">
    to work with my body id. This is why id=“webDesign” is appearing twice on the page.
    How can I get the same results with out id=“webDesign” appearing twice on the page? Thanks
  • #4 / May 31, 2010 3:46pm
    If you are using advanced conditionals you must not use the deprecated short form of {if foo}. Try this:
    <body {if embed:body_id != ""} id="{embed:body_id}"
    {if:elseif segment_1 != ""} id="{segment_1}"
  • #5 / May 31, 2010 4:53pm
    Greg8033
    I replaced my original code
    <body {if embed:body_id} id="{embed:body_id}" {if:elseif segment_1} id="{segment_1}" {if:else} id="home" {/if} class="screen">
    with the code in the last reply
    <body {if embed:body_id != ""} id="{embed:body_id}" {if:elseif segment_1 != ""} id="{segment_1}" {if:else} id="home" {/if} class="screen">
    But the id=“webDesign” is still coming up twice.
  • #6 / May 31, 2010 5:00pm
    You’ll need to do some reduction testing, I am afraid. Try to reduce your conditional to keep it as simple as possible. Perhaps start with simple ones:
    {if embed:body_id != ""}{embed:body_id}{/if}
    {if embed:body_id == "" && segment_1 != ""}{segment_1}{/if}
    Take it from there. It’s in all probability an issue with your conditional.
