Using tag value as nested parameter
May 18, 2010 1:09pm
  • #1 / May 18, 2010 1:09pm
    dsloan
    I am using nested tags, and wish to use a tag value returned by the initial tag pair, as a parameter value to pass to the nested tag pair. I’ve included the code below - this uses a plugin, but that is irrelevant I believe, since all I’m concerned about is how to use the tag value.
    {exp:rentpro:get_property id='{segment_3}'}
        <div><strong>{address1}</strong> - {town} {property_id}</div>
        {exp:rentpro:get_property_images id="{property_id}"}
            {image_name}<br>
        {/exp:rentpro:get_property_images}
    {/exp:rentpro:get_property}
    The first line containing the {address1}, {town} and {property_id} tags works/displays fine, so the plugin is returning the correct data - it’s just using this in the subsequent get_property_images call that doesn’t work.
    This syntax seems to work if I use a “native” EE tag, e.g. {segment_3} (which will work in this instance), but not if I use a “custom” tag name, e.g. {property_id}
    It also works ok if I simply supply the ID value explicitly, eg. id=“123”.
    But it doesn’t pick up the value from the {property_id} tag.
    This is similar to a snippet from the EE user documentation at http://expressionengine.com/public_beta/docs/development/module_tutorial.html
    {exp:channel:entries limit="10"}
    {title}
    {exp:download:entries entry_id="{entry_id}"}
    {file_title} - {file_download}
    {/download:entries}
    I would have thought this was a common enough occurence?
    Diarmid
  • #2 / May 18, 2010 2:41pm
    Wouter Vervloet
    Nested tags (when they are the same tag) don’t work. Just like you can’t use 2 nested channel:entries tags…
    One solution would be to embed a template with the nested tag in it.
      {embed='embeds/nested_property' property_id='{property_id}'}
    And the ‘embeds/nested_property’ template:
    {exp:rentpro:get_property_images id="{embed:property_id}"}
      {image_name}<br>
    Since embedded templates are rendered separately from their parent template, this will work.
    Greetz,
    Wouter
    [ EDIT ]
    Hmmm… Not until after I had posted it, I noticed that they weren’t the same tags you’re using.
    Could you try adding parse=‘inward’ to the rentpro:get_properties tag? That might solve your problem.
  • #3 / May 18, 2010 2:59pm
    dsloan
    Thanks Wouter - parse inward worked a treat!
