Hi am having trouble making this work in EE2. What might I not be considering? I’ve ported and uploaded the plugin.
I’m not sure I understand your method of debugging.
I’ve inserted the code you posted into an ee2 template which I’ve set to xml, I’ve set php enabled and process on input.
If I type the url in to the address bar I see
XML Parsing Error: syntax error
Line Number 1, Column 1:BEGIN:VCALENDAR
I tried adding that url to google calendar and it could not retrieve the url.
Any ideas?
