How to retrieve a custom field values with weblog:entries and show each value only once
April 26, 2010 2:32pm
  • #1 / Apr 26, 2010 2:32pm
    giusi
    I have a custom field in a channel from whom i have to retrieve the values to make a list. The custom field host a limited set of values but these values can repeat across entries (example: 10 post with value of Connecticut, 13 post with value of Minnesota and so on).
    The field must be a input text (no pre-filled dropdowns and the likes) so when i retrieve the value with weblog:entries I have each value repeatedly shown.
    How (if possible) can i tell to the engine to show each value only once?
  • #2 / Apr 26, 2010 2:56pm
    ender
    a custom SQL query leaps immediately to mind:
    SELECT DISTINCT
        field_id_XX AS my_custom_field
    FROM
        exp_weblog_data
    WHERE
        weblog_id = 2
    ORDER BY field_id_XX ASC;
    where the XX in field_id_XX is replace by the proper field_id for your custom field, using the proper value for weblog_id, and changing my_custom_field to whatever is appropriate.
  • #3 / Apr 26, 2010 3:03pm
    giusi
    ender, thank you very much for your istant support!
