Templates not updating when running on local MAMP server
April 17, 2010 2:09pm
  • #1 / Apr 17, 2010 2:09pm
    kevincannon
    Hi there,
    I’m running a test installation of EE 1.6.x using MAMP on my local machine. It’s all working fine, except for an issue with Templates.
    I’m editing the Templates directly with Dreamweaver, but the changes are not reflected when I refresh the page in the browser. The change is only affected when I open the template in the admin (I can see the changes there) and then click the update button.
    I’ve never had this problem when FTPing files up, can anyone suggest why this might be happening?
    Thanks.
  • #2 / Apr 17, 2010 2:19pm
    Flatulent Badger
    Hi there,
    Thanks.
    You may want to have a look at the Templatizer Extension described here :
    http://ellislab.com/forums/viewthread/114771/
  • #3 / Apr 18, 2010 1:00am
    kevincannon - these are existing templates you are modifying?  You are not attempting to create new templates via the filesystem?
    What version and build of EE are you using? You can find that information in the footer of your control panel.
  • #4 / Apr 19, 2010 4:39am
    kevincannon
    Yes, these are existing templates. I created them in the control panel, and then made sure ‘save as file’ was set. I then edited them directly in Dreamweaver. This is the same process as I have done many times in the past, but this time I’m running everything locally on OSX using MAMP.
    The version I have is 1.6.8.
    I’ve tried a few things and searched here extensively but have not found a solution.
  • #5 / Apr 19, 2010 8:29am
    We’ve seen some similar problems occur with Dreamweaver. Is it possible to test with another editor such as TextMate, TextWrangler, or Smultron? I’ve used all three successfully with MAMP.
  • #6 / Apr 19, 2010 9:12am
    kevincannon
    Tested with Smultron and it’s the same behaviour.
    If I had to hazard a guess I’d say it’s some kind of template caching. I have the cache turned off in template preferences, but what else could be causing this problem. It’s killing my development time.
  • #7 / Apr 19, 2010 9:16am
    Can we have you upgrade to 1.6.9? That would put both of us on the same build for testing purposes.
  • #8 / Apr 19, 2010 9:31am
    kevincannon
    Thanks for the help.
    I just updated to 1.6.9 and can confirm I still have the issue.
  • #9 / Apr 19, 2010 11:08am
    Hmm.. and I don’t. When using Smultron, are you closing the file and saving, or just saving?
  • #10 / Apr 19, 2010 12:59pm
    kevincannon
    C’mon. Of course I’m saving the file! 😊
    In fact EE is seeing the change in the control panel itself.
    Here’s what happens.
    - Create template in control panel and set ‘save as file’
    - View template page in browser
    - Make change to template via text editor.
    - Refresh template in browser, and no change. (Have tried clearing cache etc..)
    - View the template in control panel and the change is visible there.
    - Press ‘update’ button.
    - Refresh page in browser and the change is visible.
  • #11 / Apr 19, 2010 3:11pm
    I asked if you were *closing* the file in addition to *saving* it. Wasn’t sure if that would effect the outcome.
    Even after refreshing the open page, and only saving the file without closing it, I get an updated template. I’m not using any sort of caching, just a base install of 1.6.9.
  • #12 / Apr 20, 2010 8:49am
    kevincannon
    I’m sure this is not a normal problem. This is just a base install too.
    What else could cause this issue?
  • #13 / Apr 20, 2010 11:10am
    I’m not certain. I can’t replicate the problem on my MAMP installs at all.. let me ask the dev team what else could be causing the issue. Since it’s a local install, we can’t login and test. :(
  • #14 / Apr 20, 2010 6:21pm
    Other possible causes:
    Bad path. Make sure the path to your folder also includes a trailing /
    For instance, my base path is set to:
    /Applications/MAMP/htdocs/ee169/edit/
    Or permissions are off.
