Extensions problem?
March 29, 2010 5:33pm
  • #1 / Mar 29, 2010 5:33pm
    Lanitha
    Hello,
    I have a problem and I’m not sure when and how it started.
    I’m on the most recent build.
    Errors:
    - When trying to get to the extensions manager:
    Fatal error: Cannot redeclare viewpreview::$settings in /home/XYZXYZ/xx/xxxx/extensions/ext.viewpreview.php on line 27
    - When trying to use ‘Edit’ in the CP: Fatal error: Cannot redeclare viewpreview::$settings in /home/xyzxyz/xx/xxxxC/extensions/ext.viewpreview.php on line 27
    - When trying to use the tab ‘Publish’:
    MySQL ERROR:
    Error Number: 1146
    Description: Table ‘tablename.exp_lj_crosspost_fields’ doesn’t exist
    Query: SELECT field_id, lj_field, field_name FROM exp_lj_crosspost_fields WHERE field_id = 5
    Seems all the errors point to a problem with extensions? I’ve already tried a restore of the database and checking the file permissions. I also uploaded a fresh copy of the system/extensions file.
    Any suggestions?
    I’ve been away from EE for a while, so apologies if this is something extremely simple; I’ve forgotten quite a bit of things…
  • #2 / Mar 29, 2010 8:26pm
    Brandon Jones
    Hi Lanitha,
    It does sound like an extensions issue.  See this wiki entry on how to disable extensions without control panel access.
    Does that help?
  • #3 / Mar 30, 2010 8:30am
    Lanitha
    Thanks for the response Brandon. That does help for the ‘Edit’ and ‘Publish’ problems, but it still throws me that fatal error when I try to use the extension manager..?
  • #4 / Mar 30, 2010 9:46am
    The extension in question is LiveJournal. Is that the only one you’re using on the site?
  • #5 / Mar 30, 2010 10:07am
    Lanitha
    Hey Sue,
    The extensions that are used there are as follows:
    cp_jquery
    live_link
    lj_crosspost_form
    tag_submit
    viewpreview
    Do I delete the LiveJournal and ViewPreview one via FTP to see if that changes anything or is that a stupid idea?
  • #6 / Mar 30, 2010 10:14am
    There are a few ways you could handle this. One way is to truncate the extensions table, remove the offending extensions, and then re-do the ones you have left.
    How comfortable are you with doing MySQL queries?
  • #7 / Mar 30, 2010 10:40am
    Lanitha
    Thank you Sue, that solved the problem for me. 😊
  • #8 / Mar 30, 2010 10:55am
    Glad that things are working again. Don’t hesitate to post again as needed.
