How to you lift the words limit in an article?
March 26, 2010 12:38am
  • #1 / Mar 26, 2010 12:38am
    bearelite
    I notice the blog post truncates auto after a certain point. How do you remove this limit?
  • #2 / Mar 26, 2010 7:17am
    Neil Evans
    not sure what your referring to??? i have never seen a limitation that isn’t self setup.
    In your case it might be that the custom field you have is limited in the setup of that custom field - those i suspect this is not the case.
    I suspect that you template code is restricting the word limit when you have a blog list of multiple articles. As otherwise the length of this list page would be huge???
    If so i would suggest a plugin like “word_limit” has been used in the appropriate template.
  • #3 / Mar 26, 2010 7:52am
    bearelite
    I meant that there is a limit to how long the article can be. How can that limit be increased?
  • #4 / Mar 26, 2010 8:00am
    Brendon Carr
    You’ll need to edit your SQL table to change the data type to accommodate more data.
  • #5 / Mar 26, 2010 8:02am
    Neil Evans
    MySQL TEXT fields have a limit of 65,000 bytes. If you insert anything larger than that in to a normal TEXT field mySQL will silently truncate your data without telling you (meaning software checks are probably a good idea). MEDIUMTEXT will store 16 million characters and LONGTEXT can handle over 4 trillion, but this information does not appear to be readily available in the online mySQL manual
  • #6 / Mar 26, 2010 11:55am
    bearelite
    hmm…how do you make the changes in mySQL?
