weblog entry in several categories - possible to limit the number shown?
March 21, 2010 12:11pm
  • #1 / Mar 21, 2010 12:11pm
    Ross1988
    Hi
    I have a directory system set up using EE. It seems to work well, with the only exception that if an entry appears in two categories, It shows up twice when using
    {exp:weblog:entries weblog="{embed:listing_weblog}"  limit="1"}
    {categories}
    You are here: <b><a href="http://{blog_url}">{blog_title}</a></b> » <a href="http://{path={segment_1}/listings/}">{category_name}</a> » {title}
    {/categories}
    {/exp:weblog:entries}
    this code essentially creates a breadcrumb navigation, which works fine, except when an entry has two or more categories, rightly so, the “breadcrumb” is repeated X amount of times.
    this means that if a user is viewing Entry A on Category A, they see bread crumbs to Category A and Category B, so visually it’s annoying.
    is it possible to show categories dynamically in this manner - the URL contains the category of the entry it was access through if that makes sense.
    thanks
    [Mod Edit: Moved to the How to forum]
  • #2 / Mar 22, 2010 10:07am
    ender
    I wrote up something to this effect back in June 09 over here.  I used PHP to get the functionality I needed.
  • #3 / Mar 22, 2010 4:21pm
    Ross1988
    i had a feeling it would need a bit of a hack due to the way the categories tag works but this looks promising.
    will take a look, thanks.
