Since last week, out of nowhere I’m unable to upload files of any sort. I use nGen File Field for my uploads but when troubleshooting tried the default Publish upload option which always throws this error at me.
“A problem was encountered while attempting to upload your file”
When hitting Update after browsing for my file (I’ve tried both images and PDF’s with no luck) via nGen, I’m brought to the View Entry screen where I would normally see the file name but there’s nothing, so it’s not even making it this far. It won’t error right away most of the time, but after trying to upload a few times will display it’s error message with all of the previous files that wouldn’t upload queued in the error list…like it took a while for them to get a response from the server as to where they’re going or whats happening to them.
Everything else appears to be working fine, even weblogs I have already uploaded files using nGen are fine.
I’ve tried a few things in troubleshooting, like double checking the server path to the upload directory, turning off XSS filtering, and I also got my host on the phone and had him check permissions on everything, including his own temp directory; it’s a Windows server btw. I also made sure php safe mode wasn’t on, which it isn’t.
Any help would be appreciated!
