Only show nested list if there are more than 1 entry (conditonal question)
March 11, 2010 7:25am
  • #1 / Mar 11, 2010 7:25am
    Mikee Bee
    Hi all, I have a navigation that uses the first entry in a weblog as the top level list item then using offset=“1” all following entries populate a nested list.
    {exp:weblog:entries weblog="asset-based" sort="asc" limit="1" dynamic="off"}
              <li{if segment_1 == "asset-based"} class="current"{/if}><a href="#">{pages-title}</a>
              {/exp:weblog:entries}
                <ul class="nested">
                {exp:weblog:entries weblog="asset-based" offset="1" dynamic="off" sort="asc"}
                  <li><a href="#">{pages-title}</a></li>
                </ul>
              </li>
    Problem is, if there is only 1 entry the <ul> is still created and creates a gap.
    I tried adding count > 1 to my segment conditional (not sure if thats right btw) it didn’t work, then I realised I needed to wrap it in the entries tag so the ‘count’ had a reference.
    It didn’t like that (due to the nested entries tags I think) so I embedded the nested list like so…
    </li>
                   <li><a href="#}">{pages-title}</a>
              {exp:weblog:entries weblog="asset-based"}
                 {if segment_1 == "asset-based" AND count > 1}
                   {embed="includes/nav-list-item"}
    </li>
    and that jus’ plain don’t work and I’m stumped! It all works fine until I add the count > 1.
    This is the contents of the embed…
    <ul class="nested">
    </ul>
    It’ll be something simple I’d wager.
  • #2 / Mar 11, 2010 7:33am
    H&O
    Something like:
            {if count == 1}
            <ul class="nested">
            {if count == total_results}
            </ul>
    </li>
  • #3 / Mar 11, 2010 7:56am
    Mikee Bee
    I would have never thought of doing it that way! Thank you. So is count not a reference to number of entries in a weblog but the number entry so you could pinpoint the 3rd, 5th entry etc?
  • #4 / Mar 11, 2010 9:25am
    H&O
    Jup!
  • #5 / Mar 11, 2010 9:54am
    Mikee Bee
    So would mine have worked if there was something that meant
    {if THERE IS MORE THAN 1 ENTRY IN THIS WEBLOG}
    Does such a thing not exist?
  • #6 / Mar 11, 2010 1:43pm
    H&O
    Do you mean:
    {if count >= 3}
    Do something for the 3rd entry and above
  • #7 / Mar 12, 2010 5:28am
    Mikee Bee
    Yeah, would that have worked with my original method?
