Am I to understand it’s not possible to use Related Entries more than a single time in a weblog entry? The code below ends up yielding a string of gobbledygook, but when I use only a single instance of Related Entry, everything works as expected.
{exp:weblog:entries weblog="weblogname"}
{title}
{body}
{related_entries id="customfield_1"}{fieldname}{/related_entries}
{related_entries id="customfield_2"}{fieldname}{/related_entries}
{related_entries id="customfield_3"}{fieldname}{/related_entries}
{/exp}In this case, I happen to also be using Conditional Global Variables, but with or without, the results are the same. Basically it outputs thusly:
{REL[customfield_1]LLkhQT49REL}
{REL[customfield_2]cB40XeroREL}
{REL[customfield_3]XdTkINfzREL}
Before I shell out for Playa or some other plugin or extension that would potentially resolve this, I was wondering if there was an existing solution. Thanks!
