RSS template issue
February 24, 2010 10:14am
  • #1 / Feb 24, 2010 10:14am
    George K
    I want to include in the RSS feed different templates sets.
    Is it possible to do this:
    If master web log name = weblog1 then :
    <link rel="alternate" type="text/html" href="http://mywebsite/index.php/id/{entry_id}" />
    If master web log name = weblog2 then :
    <link rel="alternate" type="text/html" href="http://mywebsite/index.php/id3/{entry_id}"
    (the change is simply in the id after index.php)
    Is this possible?? If yes, can I get some example code?
  • #2 / Feb 24, 2010 3:21pm
    I don’t see why not? What have you tried so far? Can you show us a little more of your code? It looks like a simple conditional might suffice.
  • #3 / Feb 24, 2010 3:27pm
    George K
    Well this is the code. I have never used an if statement.
    Is it possible you give ma a hint and I will take it from there?
    {assign_variable:master_weblog_name="buy_sell_hold|special_situation|global_macro|essay|all_forex| charts|market_intelligence | market_talk_news|  podcast"}
    {assign_variable:atom_feed_location="site/atom"}
    {exp:rss:feed weblog="{master_weblog_name}"}
    <?xml version="1.0" encoding="{encoding}"?>
    <feed >
        <title type="text">{exp:xml_encode}{weblog_name}{/exp:xml_encode}</title>
        <subtitle type="text">{exp:xml_encode}{weblog_name}:{weblog_description}{/exp:xml_encode}</subtitle>
        <link rel="alternate" type="text/html" href="{weblog_url}" />
        <link rel="self" type="application/atom+xml" href="{path=/feed/atom}" />
        <updated>{gmt_edit_date format='%Y-%m-%dT%H:%i:%sZ'}</updated>
        <rights>Copyright (c) {gmt_date format="%Y"}, {author}</rights>
        <generator uri="http://expressionengine.com/" version="{version}">ExpressionEngine</generator>
        <id>tag:{trimmed_url},{gmt_date format="%Y:%m:%d"}</id>
    {exp:weblog:entries weblog="{master_weblog_name}" limit="15" rdf="off" dynamic_start="on" disable="member_data|trackbacks"}
        <entry>
          <title>{exp:xml_encode}{title}{/exp:xml_encode}</title>
          <link rel="alternate" type="text/html" href="http://www.market-talk.net/index.php/id/{entry_id}" />
          {gmt_entry_date format="%Y-%m-%dT%H:%i:%sZ"}</published>
          <author>
                <name>{author}</name>
                <email>{email}</email>
                {if url}<uri>{url}</uri>{/if}
          </author>
    {categories}
          <category term="{exp:xml_encode}{category_name}{/exp:xml_encode}"
            scheme="{path=site/index}"
            label="{exp:xml_encode}{category_name}{/exp:xml_encode}" >{/categories}
          <content type="html"><![CDATA[
           {summary}
    Original link:<a href="http://www.market-talk.net/index.php/id/{entry_id}">http://www.market-talk.net/index.php/id/{entry_id}</a>
          ]]></content>
        </entry>
    {/exp:weblog:entries}
    </feed>
    {/exp:rss:feed}
  • #4 / Feb 24, 2010 5:14pm
    You can read more about conditionals here. Let me move this thread to Howto for you.
  • #5 / Feb 24, 2010 6:15pm
    George K
        <entry>
    {if weblog == "contrarian"}
    {if:else weblog != "contrarian"  }
          <link rel="alternate" type="text/html" href="http://www.market-talk.net/index.php/id3/{entry_id}" />
    Ok I tried this and I get errors. I also tried {master_weblog_name} instead of weblog and got the same thing.
    What am I missing?
  • #6 / Feb 24, 2010 6:30pm
    George K
    Ok I got the erros to stop.
    But now I have another problem.
    in this code:
    {if:else}
    I always get the second statement to execute, even though the weblog contrarian registers in the feed.
    Am I using weblog wrong or something?
  • #7 / Feb 24, 2010 6:36pm
    George K
    I have tried
    weblog and {weblog_short_name} and I get the same result
  • #8 / Feb 24, 2010 6:38pm
    George K
    hmmmm I found it
    I used
    {if (weblog_short_name) == "contrarian"}
    And it worked!!
    Is there another way?
