Captcha Image not appearing in comments
February 24, 2010 12:47am
Subscribe [5]
  • #1 / Feb 24, 2010 12:47am
    h0lj0n
    Hi
    The text telling people to write the image appears, but not the image itself. I think it’s because I don’t have the correct server path to captcha folder set up in my admin captcha preferences. However, I don’t know what my correct server path to captcha folder is. I’ve taken a couple of stabs at it and done some internet searches to try to figure it out, but no dice.
  • #2 / Feb 24, 2010 2:29am
    h0lj0n,
    You can find your server path by going to your General Configuration  and looking at the Theme Folder Path under
    CP Home ›  Admin ›  System Preferences ›  General Configuration
    so if your path is something like
    here/here/public_html/themes/
    then change it to
    here/here/public_html/images/captchas/
    for your Captcha Preferences
    Make sure that folder has permissions of 777 on it
    What code are you using to show the Captcha in your template?
  • #3 / Feb 24, 2010 3:48pm
    h0lj0n
    Thanks John.
    my Theme Folder Path says it is:
    /home/content/h/o/l/holjon/html//themes/
    I tried to change that to
    /home/content/h/o/l/holjon/html//images/captchas
    but it keeps coming up as invalid
    i did set the permissions of the folder to 777
    the code i’m using is the same code that is posted in the user guide:
    {exp:comment:entries weblog="{my_weblog}" limit="25"}
    <div class="comments">
    {comment}
    <div class="posted">Posted by {url_or_email_as_author}   on  {comment_date format='%m/%d'}  at  {comment_date format='%h:%i %A'}</div></li>
    </div>
    {paginate}
    <div class="paginate">
    <span class="pagecount">Page {current_page} of {total_pages} pages</span>  {pagination_links}
    </div>
    {/paginate}
    {/exp:comment:entries}
    {exp:comment:form preview="{my_template_group}/comment_preview"}
    {if logged_out}
    Name:
    <input type="text" name="name" value="{name}" size="50" />
    Email:
    <input type="text" name="email" value="{email}" size="50" />
    <input type="text" name="location" value="{location}" size="50" />
    URL:
    <input type="text" name="url" value="{url}" size="50" />
    <a >Smileys</a>
    <textarea name="comment" cols="50" rows="12">{comment}</textarea>
    {if logged_out}
    <input type="checkbox" name="save_info" value="yes" {save_info} /> Remember my personal information
    <input type="checkbox" name="notify_me" value="yes" {notify_me} /> Notify me of follow-up comments?
    {if captcha}
    Submit the word you see below:
    {captcha}
    <input type="text" name="captcha" value="{captcha_word}" size="20" maxlength="20" style="width:140px;" />
    <input type="submit" name="preview" value="Preview" /></p>
    {/exp:comment:form}
  • #4 / Feb 24, 2010 3:49pm
    h0lj0n
    just to be clear, i tried to update my captcha path to:
    based on what i found under the general config
  • #5 / Feb 24, 2010 7:37pm
    Adam Dorsey
    /home/content/h/o/l/holjon/html/themes/
    /home/content/h/o/l/holjon/html/images/captchas
    You are changing the captcha path, and not the themes path, right?
  • #6 / Feb 25, 2010 1:10am
    h0lj0n
    yes. right.
  • #7 / Feb 25, 2010 2:30am
    h0lj0n,
    What is the invalid error you see?
    Can you try removing the extra forward slash in there so it only appears as
  • #8 / Feb 25, 2010 2:10pm
    h0lj0n
    i removed the slash and i still receive the same error which is:
    “the following path you submitted is not valid”
    so it won’t let me update it
  • #9 / Feb 25, 2010 9:06pm
    Adam Dorsey
    Try, using this php script to determine the correct path to that folder?
    Does this make sense?
  • #10 / Feb 25, 2010 10:25pm
    h0lj0n
    where do i use that script?
    also, you typed “http:” twice. is that correct?
  • #11 / Feb 25, 2010 11:21pm
    h0lj0n
    I finally have the server path correct. Now a “?” appears.
  • #12 / Feb 26, 2010 12:10am
    h0lj0n
    i have no idea if i have a gd library installed nor does any of the documentation from google searches make sense to me. is there a way to know if i have a gd library installed, and, if not, learn how to install it? i can’t find much info on the expression engine knowledge base.
  • #13 / Feb 26, 2010 2:09am
    h0lj0n,
    Use our Server Wizard from our Requirements page to determine if you have GD installed
    Take a look inside your images/captcha folder. Are any images being generated in there?
  • #14 / Feb 26, 2010 1:51pm
    h0lj0n
    I contacted my system admin folks and found out that the gd library is part of their standard installation.
    and yes, there are images being created in the captcha folder. a whole bunch from today in fact.
    i have the true type thing turned off. i don’t know what else to do.
  • #15 / Feb 26, 2010 5:00pm
    Is the issue that you’re logged in when you look at the comment form?
    What happens if you log out and try this as a non-logged in (Guest)?
