Link Based on User's IP Address
February 22, 2010 1:21pm
  • #1 / Feb 22, 2010 1:21pm
    ParisJC
    We have certain services on campus that are accessed by students and faculty in different ways, depending on whether they are accessing via our campus network or from off-campus. Rather than utilize two links, I’d like some way for the user’s IP address to be recognized (i.e., is on-campus or not) and the appropriate link provided automatically (or via a redirect of some type).
    Such a thing possible? Anyone ever done this?
  • #2 / Feb 22, 2010 1:42pm
    lebisol
    Can you use “logged in/out” instead of IP?
    If you have a DNS server on your campus you can always setup Forward Lookup Zone so that those links are valid.
    You can also look into using PHP to detect user IP.
  • #3 / Feb 22, 2010 1:54pm
    ParisJC
    Hi, lebisol.
    We can’t use logged in/out since we only require logins for some faculty and staff areas. Student use is open on the general site, and login for mail and other areas is on a different system than EE. The link(s) in question lead to those areas.
    I knew EE could provide the IP address of a user, but thought it was only if the user is logged in. However, I just ran a quick test, and EE provided the IP address when I was logged out. So I may be able to set up a simple conditional to provide the correct link:
    if ip_address == our C block
    —insert link A
    if:else
    —insert link B
    Or can ip_address be used as in a conditional?
  • #4 / Feb 22, 2010 2:08pm
    lebisol
    Agh I figured but though to go the easy route first.
    Not sure about how EE collects IPs but my first guess would be to use query module and perhaps look into ‘exp_sessions’ or ‘exp_online_users’ tables.
    eg.
    {exp:query sql="SELECT ip_address FROM exp_online_users;"}
     {if {ip_address} != 'xxx.xxx.xxx.xxx'}
      Not on Campus
    {/exp:query}
  • #5 / Feb 22, 2010 3:11pm
    ParisJC
    Thanks for that tip. I’ll give that a whirl when I get back to the office in the morning.
  • #6 / Feb 22, 2010 4:21pm
    ender
    since you want to check for a matching IP down to the C block and not an exact match you won’t be able to do this with a simple {if} condition tag.
    I’d give Mark’s Switchee plugin a try in this case, since it supports regular expressions now.
    {exp:switchee variable="{ip_address}" parse="inward"}
        {case value="#192\\.168\\.1\\.[0-9]{1,3}#"}
            <a href="http://whatever">asdf</a>
        {/case}
        {case default="Yes"}
            <a href="http://something_else">qwer</a>
        {/case}
    {/exp:switchee}
    also fwiw: the {ip_address} tag is a global variable so you don’t need to perform a separate query to get it.
  • #7 / Feb 23, 2010 10:35am
    ParisJC
    Hadn’t seen that. Thanks, ender!
