Assigning class="active" to Current Page
February 14, 2010 11:21pm
Subscribe [11]
  • #1 / Feb 14, 2010 11:21pm
    B-n-H
    I’m working on embeds currently and i have {embed="global/header"} in my main template. In the header template I have my logo/menu and I was wondering how do I have the menu list item display as active for the current page?
    Like if I have the pages Home, Work, About Contact and I’m currently on the “About” page it would look like this:
    <ul>
    <li><a href="/home">Home</a></li>
    <li><a href="/work">Work</a></li>
    <li class="active"><a href="/about">About</a></li>
    <li><a href="/contact">Contact</a></li>
    </ul>
    I ask because the only way I can do this while keeping {embed="global/header"} is if its done dynamically somehow.. if not I would think I would have to add the menu to every page and add the class=“active” to the right pages
  • #2 / Feb 14, 2010 11:52pm
    Gareth Davies
    Specify a parameter in your embed so something like:
    {embed=“global/header” loc="home"}
    Just change the loc parameter to whichever section you are on then add some conditionals to the template:
    <ul>
    <li {if embed:loc == "home"}class="active"{/if}><a href="/home">Home</a></li>
    <li {if embed:loc == "work"}class="active"{/if}><a href="/work">Work</a></li>
    <li {if embed:loc == "about"}class="active"{/if}><a href="/about">About</a></li>
    <li {if embed:loc == "contact"}class="active"{/if}><a href="/contact">Contact</a></li>
    </ul>
    Then on your About page use:
    {embed=“global/header” loc="about"}
    and so on…
  • #3 / Feb 15, 2010 1:01am
    B-n-H
    <ul>
    </ul>
    and so on…
    is there a way for this to work if a new page is created? it seems what i would have to do is add
    {embed=“global/header” loc="newpage"}
    if a new page is created right?
    im still learning, but if this were for a clients site they wouldnt know about adding the template so just curious if theres another way
    thanks!
  • #4 / Feb 15, 2010 6:04am
    Mark Bowen
    If all your top level menus are set like this :
    http://www.example.com/home
    http://www.example.com/work
    http://www.example.com/about
    http://www.example.com/contact
    then you should just be able to do something like this :
    <li {if segment_1 == "home"}class="active"{/if}><a href="/home">Home</a></li>
    and so on and so forth.
    Hope that helps a bit.
    Best wishes,
    Mark
  • #5 / Feb 15, 2010 7:06am
    Chris Jennings
    All of the above + some other ideas that I use:
    If this is a single entry page then you can add the style into the page:
    <style type="text/css" media="screen">
    body.{weblog_short_name} .submenu li#{url_title} a
    background: #dee2e5;
    color: #002145;
    </style>
    </head>
    <body class="{weblog_short_name}">
    and then on the menu or tabs:
    {embed="includes/.submenu" section="{weblog_short_name}" myid="{entry_id}"}
    then in the submenu template something along these lines:
    {if entry_id!=="{embed:myid}"}
    <li id="{url_title}"><a href="http://{url_title_path={embed:section}}%22class=%22{status}" title="read about {title}" class="{status}">{title}</a></li>
    {if:else}
    <li id="{url_title}"><a href="#%22class=%22{status}" title="you are here" class="{status}">{title}</a></li>
    The last conditional prevents the link from self reference if you are already on that page..
    Also note the use of status in the class name for the link. This can then display the menu item in a different colour depending on its status (open,reviewed,pending or whatever).
    Hope this helps…
  • #6 / Feb 15, 2010 4:20pm
    marcamos
    You can also do this with CSS alone.
    In the navigation:
    <ul>
    <li id="navLinkHome"><a href="http://">Home</a></li>
    <li id="navLinkAbout"><a href="http://">About</a></li>
    <li id="navLinkThing"><a href="http://">Thing</a></li>
    <li id="navLinkAlso"><a href="http://">Also</a></li>
    </ul>
    In each page’s opening body tag:
    <body class="homePage"> ...
    In your CSS:
    .homePage #navLinkHome,
    .aboutPage #navLinkAbout,
    .thingPage #navLinkThing,
    .alsoPage #navLinkAlso {
         /* Whatever properties/values your .active class had, for example: */
         color: red;
  • #7 / Feb 16, 2010 1:38pm
    PhilBrienesse
    Mark’s way is the most common I use.  You can also extend it to sub-nav with a slight modification.  Compare segment_2 to the url_title when you are on a specific page as opposed to a section.
  • #8 / Mar 05, 2010 6:15pm
    Curtis Scott
    I’m having trouble getting this to work for me.
    I have a site template named ‘home’ and this is my code:
    <li class="home" {if segment_1 == "home"}class="current"{/if}><a href="/home"><span>Home</span></a></li>
    Is there any other setting I need to adjust or should this be working fine?
  • #9 / Mar 06, 2010 7:10pm
    Adam Dorsey
    @PureDezigner - You can’t define 2 classes like that. You would have to do something like this:
    <li class="home{if segment_1 == "home"} current{/if}"><a href="/home"><span>Home</span></a></li>
  • #10 / Mar 06, 2010 7:13pm
    Adam Dorsey
    I agree, I use the method Mark mentioned. It is the easiest to implement, and the most scalable, in my opinion.
  • #11 / Mar 06, 2010 8:02pm
    Curtis Scott
    Works perfectly, thanks!
  • #12 / Mar 07, 2010 11:24pm
    ChiefAlchemist
    Another vote for Mark’s method. Segment_x is EEssential.
  • #13 / Mar 08, 2010 7:08am
    Mark Bowen
    No problem. Glad it helped a bit.
    I’d definitely recommend playing around with all of this for a while though as the other methods shown above are really good to use too. It all really depends on your situation as to which is the best though. My method is really simple and will work nearly every time but there are some really neat tricks shown above which are great to use at other times too.
    Best wishes,
    Mark
