Display Weblog (channel) entries pending on a conditional checkbox custom field
February 09, 2010 9:58am
  • #1 / Feb 09, 2010 9:58am
    gamma911
    Is there a parameter ( or if ) for displaying weblog entries pending on a checkbox being ticked when the entry is entered?
    So I add a custom field ( Display on the home page ) and if it is ticked it will cycle through all the entries in the weblog and display only those with the ticked custom field.
  • #2 / Feb 09, 2010 12:42pm
    lebisol
    welog parameter for custom field is considered to be ‘search’ rather then standard parameter.
    But it does not allow for checkbox value.
  • #3 / Feb 09, 2010 12:43pm
    gamma911
    So the solution would be to ad a drop down of yes/no
    Any other solutions?
  • #4 / Feb 09, 2010 12:46pm
    lebisol
    Other than what you mentioned….Status parameter maybe?
  • #5 / Feb 09, 2010 12:50pm
    gamma911
    I am already using the status parameter to filter entries elsewhere and as you can only apply one status, it probably wouldn’t work.
    Thanks for the idea tho, I’ll try it and post the outcome here.
  • #6 / Feb 09, 2010 1:00pm
    lebisol
    Yeah I figured but the drop down toggle would work just keep in mind it will has a value by default since it is a dropdown.
    Lastly, perhaps pre-determined category?
    Other than that you would have to build entries by using a query tag…which is not too bad but you loose the EE native weblog tag and parameters.
