If a non-logged in user gets an error on, say /index.php/fr, how can I ensure that the error uses the French language pack?
February 07, 2010 5:20pm
Subscribe [5]#1 / Feb 07, 2010 5:20pm
#2 / Feb 07, 2010 6:07pm
Hi suenovo,
Do you mean a standard EE user error message?
Cheers
Greg
#3 / Feb 07, 2010 6:24pm
Hi Greg,
That’s right, the messages like “Thank you, your password has been reset, etc. etc”.
#4 / Feb 08, 2010 1:12am
suenovo,
The language packs reflect the preference for the logged in user. If you want to create something a bit more custom you could try this extension. That way you can write in conditional user messages per language.
#5 / Feb 08, 2010 12:58pm
Aha, thank you, I’ll check that out!
Without a plugin… Does that mean that on the log in page, the errors for wrong password, etc, will always be in English, since the user isn’t logged in?
#6 / Feb 08, 2010 3:53pm
You can have a default setting, whether it’s English or some other pack, that is used for non logged-in users. Go to My Account > Member Preferences > Use this member’s localization settings as the master site default?
