Hi, have a friend using a Mac and needs to convert from Quicktime to FLV. I’m on Windows and use After Effects, so I’m no help to them.
Anyone know a good, cheap or free program to convert from mov to flv format on a Mac?
Thanks in advance.
February 02, 2010 5:37am
Subscribe [3]#1 / Feb 02, 2010 5:37am
Thanks in advance.
#2 / Feb 02, 2010 7:24am
I prefer Adobe Flash (with the included Media Encoder) for this, but your friend could also use FFmpeg via http://ffmpeg.org/ - that one works very well as well and is free.
#3 / Feb 02, 2010 7:59am
That might work, but really could use something for a non IT person. Flash would be too difficult and cost prohibitive for them for sure.
Thanks for the link.
#4 / Feb 02, 2010 8:09am
Right on.
There’s also ffmpegX which has a GUI, see http://ffmpegx.com/ - this might make more sense.
Alternatively, you could write a bash script for your friend that would take “input.mov” and return “output.flv” - he’d then have to rename “output.flv” to whatever he needs and upload it.
#5 / Feb 02, 2010 8:33am
That looks pretty cool Kerim, but I don’t see flv listed as a file format it converts to. But I’ll give it a try and see if they might be able to use it, thanks.
#6 / Feb 07, 2010 8:27am
He can also try Xilisoft Video converter. It supports several video formats including quicktime and flv. I’ve been using it for several years now for my video converting tasks.
#7 / Feb 14, 2010 3:28pm
Macvide FlashVideo Converter - that’s the best tool I’ve ever used! It’s rly fast and easy-to-use)
