Assign Variable from embed result. Possible?
January 20, 2010 5:10pm
  • #1 / Jan 20, 2010 5:10pm
    anthonys
    I would like to do something like so:
    {assign_variable:the_entry_id=" {embed="site/number_finder" segment="{segment_3}” }  ” }
    But on page its showing:
    Parse error: syntax error, unexpected ‘{’ in /core/core.functions.php(634) : eval()‘d code on line 16
  • #2 / Jan 20, 2010 5:42pm
    Peter Ripley
    Have you tried assigning the variable in the embedded template, instead of in the embedding template?
  • #3 / Jan 20, 2010 5:48pm
    anthonys
    Yea, if I do it that way I can’t use the assigned variable in the parent template. An assigned variable will only work it the template you assign it in it seems. I need to use it in the parent, not the embed.
  • #4 / Jan 20, 2010 5:57pm
    Focus Lab Dev Team
    It might have to do with the level of quotations, this is untested but try this
    {assign_variable:the_entry_id=”{embed='site/number_finder' segment='{segment_3}'}"}
  • #5 / Jan 20, 2010 6:12pm
    anthonys
    Thanks Eric, that got it working. 😊
