Links are not working any more
January 12, 2010 1:35pm
Subscribe [4]
  • #1 / Jan 12, 2010 1:35pm
    matthew235
    My links are messed up…..
    for instance the login form displays an action of
    action=“http://www.fairsandfestivals.net/http://www.fairsandfestivals.net/index.php”
    and all the {path=states}NV
    come out http://www.fairsandfestivals.net/http://www.fairsandfestivals.net/index.php/states/NV/
    System Config Value:
    URL to the root directory of my site =
    Any ideas what this may be?  Please help this is a fairly high traffic site and I’m in panic mode!!!
    Thank you very much
  • #2 / Jan 12, 2010 2:24pm
    lebisol
    Odd, do yo have anything in path.php?
    OR
    check your weblog preferences under:
    CP Home ›  Admin ›  Weblog Administration ›  Weblog Management ›  Edit Weblog Preferences
    [Path Settings]
  • #3 / Jan 12, 2010 2:58pm
    matthew235
    $system_path = "./system/";
    // MANUALLY CONFIGURABLE VARIABLES
    // See user guide for more information
    $template_group = "";
    $template = "";
    $site_url = "";
    $site_index = "";
    $site_404 = "";
    $global_vars = array(); // This array must be associative
    That is this contents of path.php.
    These links are not inside a specific weblog, so I dont think that the weblog path settings are relevant, but i will check those also.
  • #4 / Jan 12, 2010 3:39pm
    matthew235
    The weblog paths are all normal looking, such as
    http://www.fairsandfestivals.net/articles/view/
    does anybody have any idea why my {path=}  would evaluate to :
  • #5 / Jan 12, 2010 3:48pm
    Joe Michaud
    I think I’ve seen this before and here is my theory of what may be happening to you…
    In the preferences for that particular weblog look in the section called “weblog posting preferences”.  You should see an option labeled “Automatically turn URLs and email addresses into links?”.  If it is set to “yes” then try setting it to “no” and see if things behave better.
    Good Luck!
  • #6 / Jan 12, 2010 5:07pm
    matthew235
    Joe,
      Thanks for the tip, but this is not inside an exp:weblog:entries tag.  (well some of the {path=} tags are, but the ones outside an entries tag are doing it also.
  • #7 / Jan 12, 2010 5:14pm
    What do you have the “index” of your site set to?
  • #8 / Jan 12, 2010 5:24pm
    matthew235
    Name of your sites index page:
    Thank you so much for your help… i’m freaking out!!  lol
  • #9 / Jan 12, 2010 5:32pm
    It should only be “index.php”. Remove the leading http:// etc.
  • #10 / Jan 12, 2010 5:35pm
    matthew235
    Nailed it!! you rock!!
  • #11 / Jan 12, 2010 5:37pm
    I’m very glad to see that was it 😊 Please don’t hesitate to post again as needed.
