I get a blank page if i use conditionals
January 11, 2010 11:44am
  • #1 / Jan 11, 2010 11:44am
    Mike Verbruggen
    I build a website on a development environment. And today i was moving over everything to an other server. After changing the settings to suit the new environment i checked-out front-end and all i got was a blank page :-( While on the dev-server everything was OK.
    After trying all kinds off solutions i discovered the problem.
    On the new server pages show up empty if i use conditionals.
    Well, i searched and tried everything and i cant find the solution.
    Please HELP!
    I use EE 1.6.8 build 20091201
    The new-server is running PHP Version 5.2.6
    The dev-server is running PHP Version 5.2.6-1+lenny4
    I disabled the extensions whit no effect
  • #2 / Jan 11, 2010 12:13pm
    lebisol
    ...and if no conditionals page shows up ok?
    What is your code that might be throwing it of?
  • #3 / Jan 11, 2010 12:32pm
    Thanks for the assist, lebisol.
    Maix, can you give an example of the code you’re using?
    Try a brand new template with *just* this code:
    {if logged_in}
    You're logged in!
    {if:else}
    You aren't logged in!
  • #4 / Jan 11, 2010 1:08pm
    Mike Verbruggen
    What i tried,
    {username}
    Result: My name..
    {exp:weblog:entries weblog="pages" disable="categories|category_fields|member_data|pagination|trackbacks"}{if no_results}{redirect="404"}{/if}
        {pages_title}
        {pages_paragraphs}
            {text}
        {/pages_paragraphs}
    {/exp:weblog:entries}
    Result: A page with content..
    {if logged_in}
    You're logged in!
    {if:else}
    Result: A blank page..
    {if member_id == "1"}Your the Admin!{/if}
    {exp:weblog:entries weblog="showreel" disable="categories|category_fields|member_data|pagination|trackbacks" dynamic="off" }{if no_results}{redirect="404"}{/if}
    {if count == "1"}1{if:else}0{/if}
    {title}
    {title}
    In the meantime i will try a clean install in the same server…
  • #5 / Jan 11, 2010 2:07pm
    Mike Verbruggen
    This is not good. :-(
    On the clean install i have the same problem.
    I tried the Server Wizard and it is telling me, everything is OK
  • #6 / Jan 11, 2010 2:53pm
    lebisol
    {if logged_in} - try clear cache (browser and db)
    {if member_id == "1"} - are you sure super admin is really a member id 1?
    what if you eliminate if:else logic into :
    {if something}
    do
    {if something_else}
    go
    just throwing some ideas…not sure if any of it will help.
  • #7 / Jan 11, 2010 3:11pm
    Mike Verbruggen
    We found this error in error-log
    PHP Fatal error: SUHOSIN - Use of eval is forbidden by configuration in /bla/bla/bla/system/core/core.functions.php(634) : eval()‘d code on line 634
    The client will contact the hosting company tomorrow about this error.
  • #8 / Jan 11, 2010 4:39pm
    Certainly looks like a server issue, yes. Let us know how it goes.
  • #9 / Jan 12, 2010 5:59pm
    Mike Verbruggen
    Problem Solved!
    The server was installed with patches of the Hardened PHP Project. (http://www.hardened-php.net/suhosin/)
    One part of the patches blocks the eval funktion.
    In vhost.conf you can un block the eval funktion. (read te website)
    Thanks for your support!
    Next problem please…
  • #10 / Jan 12, 2010 6:15pm
    Glad to see you’re all set. Please don’t hesitate to post again as needed.
