Error when calling cURL
January 07, 2010 11:15am
Subscribe [4]
  • #1 / Jan 07, 2010 11:15am
    Stuart Whitman
    I get the following error when calling cURL from one of my templates.
    CURLOPT_FOLLOWLOCATION cannot be activated when in safe_mode or an open_basedir is set in ../core/core.functions.php(634
    According to PHP info:
    open_basedir    /home/plancars/:/tmp:/usr/local/lib/php/
    safe_mode    Off
    safe_mode_exec_dir    no value
    safe_mode_gid    Off
    safe_mode_include_dir    no value
    I have the same code running on another domain and it works fine and I’m a bit lost as to what I can do now.
  • #2 / Jan 07, 2010 5:17pm
    Can you show us a little more of your code? Is this raw PHP? What version and build of EE are you on? That said, are you quite certain that there is no open_basedir restriction in effect?
  • #3 / Jan 07, 2010 5:27pm
    Stuart Whitman
    EE 1.6.8 with MSM. Template is PHP enabled on INPUT.
    {exp:freeform:entries}
    $email_address = '{x_ff1e}';
    $join_mail = '{joinlist}';
    if (isset($join_mail)) {
                    $postfields="email_address=".$email_address;
                    $url = 'http://oi.vresp.com?fid=5724d2d65c';
                    $ch = curl_init();    // initialize curl handle
                    curl_setopt($ch, CURLOPT_URL,$url); // set url to post to
                    curl_setopt($ch, CURLOPT_FAILONERROR, 1);
                    curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);// allow redirects
                    curl_setopt($ch, CURLOPT_RETURNTRANSFER,1); // return into a variable
                    curl_setopt($ch, CURLOPT_TIMEOUT, 3); // times out after 4s
                    curl_setopt($ch, CURLOPT_POST, 1); // set POST method
                    curl_setopt($ch, CURLOPT_POSTFIELDS, $postfields); // add POST fields
                    $result = curl_exec($ch); // run the whole process
                    curl_close($ch);
                    echo $result;
                    echo 'Your email address ' .$email_address. ' has been added to the Plancars Mailing List as requested. We never pass on your details to other organisations or send SPAM emails.';
    {/exp:freeform:entries}
    I don’t know enought about open_basedir but I haven’t knowingly changed anything.
  • #4 / Jan 07, 2010 7:28pm
    Adam Dorsey
    If you check out PHP info, in Utilities in the CP, what do you have for the line “open_basedir”?
  • #5 / Jan 08, 2010 6:42am
    Stuart Whitman
    Hi Adam,
    Here’s my PHP info
    open_basedir = /home/plancars/:/tmp:/usr/local/lib/php/
    safe_mode = Off
    safe_mode_exec_dir = no value
    safe_mode_gid = Off
    safe_mode_include_dir = no value
  • #6 / Jan 08, 2010 7:23pm
    Adam Dorsey
    Hmm… I have no value listed in my install. Can you contact your host, and see if you in fact have an open_base_dir restriction?
  • #7 / Jan 09, 2010 8:55am
    Stuart Whitman
    Adam,
    I’m pretty sure thats not the case as I have another domain on the same server running EE 1.3.2 with the same code. All be it not inside the freeform tags. The PHP info between the 2 sites shows the same safe mode and open base values.
    I’ll check anyway.
  • #8 / Jan 10, 2010 4:17pm
    Greg Salt
    Hi Stuart,
    Your phpinfo() result does show that an open_basedir restriction is in force. Please create another blank template with PHP enabled and try your code outside of Freeform to test whether you get the same response.
    Cheers
    Greg
