Hi everyone,
It’s been a while, but I’m back. 😊
I’m having installation issues with EE 1.6.8 using Virtualmin 3.75 GPL on Debian 5 (lenny). After filling in all required data (db info, username, etc) I get a pretty much blank page (install.php?page=5) with just the logo.
I have both renamed and not renamed the system folder to no avail. That doesn’t seem to make any difference.
I have turned on PHP logging, but nothing get’s logged. Turns out display_errors was on all the time and nothing gets written to log or screen. Magic_quotes_gpc is now off, as is register_globals.
Right now, these are the errors I get (which is more than I got 5 minutes ago):
1. Unable to locate the file called “config.php”. Please make sure you have uploaded all components of this software.
2. Unable to locate the database file. Please make sure you have uploaded all components of this software.
3. Unable to locate the file containing your email templates. Make sure you have uploaded all components of this software.
I have uploaded the complete contents of the EE zipfile.
Of course, I have followed the installation instructions and I have succesfully installed EE several times before, just not using Virtualmin.
Is there any Virtualmin / Debian 5 voodoo I should be aware of? Any settings I might check or may have overlooked?
Thank you for any insight you might provide!
Be well… Nico
