Simple URLs not working after move to new hosting
December 14, 2009 12:05pm
  • #1 / Dec 14, 2009 12:05pm
    ITCC
    I recently moved a client’s site to a new hosting account.  I have gone through the KB checklist and updated all the paths etc.
    However, I am having trouble with linking to items in a folder in my site root.  What I believe is causing problems is that EE is reading links to this folder as links to templates/template groups.  What confuses me though is that the ‘Images’ folder works just fine and operates on the same principle as my problem folder. (Permissions are read-write, so I don’t think that’s the problem)
    Any wisdom would be greatly appreciated!
  • #2 / Dec 14, 2009 12:08pm
    Have you considered using Deeploy Helper to aid in setting paths?
  • #3 / Dec 14, 2009 1:10pm
    ITCC
    Thanks Sue, I will check that out.
    I think I should explain a little better what I am doing though.  On this particular site, there are several custom forms and with them, I am using the securimage PHP script for captchas.  Everything needed for the script is in a folder in the site root called ‘php’.
    On the pages with the forms, the captchas are not displaying.  When you access the script which renders the captcha directly, you get a string of strange text characters.
    I put a test php file with a simple echo in the ‘php’ folder.  When i try to access it, EE behaves as though I’m trying to access a template group that isn’t there.
    For what it’s worth, the site has Force Query Strings on.
    Hope this helps some more.
  • #4 / Dec 14, 2009 5:25pm
    What version and build of EE are you using? Do you’ve got a link? Are you removing index.php from your URLs?
  • #5 / Dec 14, 2009 5:36pm
    ITCC
    I’ve solved a little of my problem - part of it was a mix up: I was poking around in the wrong hosting account.  However, the captcha image is still not showing.
    I’m on EE build 1.6.4.
    For the time being, our client is on a free GoDaddy hosting account until he upgrades it.  I am starting to think that the GoDaddy ad banner is what’s messing everything up, because everything else works…
    This page should render the captcha: http://www.aarrowtransmissions.com/php/securimage_show.php
    I was removing the index.php on the old hosting, but I turned all that off (I think) on the new hosting account until the dust settles.
  • #6 / Dec 14, 2009 6:01pm
    Yes, the link you gave me shows a .png which Godaddy adds an iframe to. Definitely try on regular hosting, please.
  • #7 / Dec 15, 2009 9:51am
    ITCC
    I will check back once the client has upgraded their hosting.  Thanks all!
  • #8 / Dec 15, 2009 9:52am
    We’ll be here!
