I am having issues with the relationship custom field type.
I have several custom fields of type “relationship”. When I attempt to print them out, all the but the last one appear like so:
{REL[locations]y5hosOTWREL}
{REL[construction_contractor]ydOKUwDBREL}
{REL[owner]cOF23txKREL}If I change the order, the final field is the only one that works.
If I wrap each fields in its own entries tags, it works. However there are about 6 relationships, and this doesn’t seem like the best solution.
My first question is: is it possible to have more than one relationship field for a weblog? And secondly, any idea what might be happening?
I have had both multiple relationships and Playa running, though they are both disabled now and the problem persists. I am also using MSM.
Thanks in advance.
Paul
