How to customize 404 Error Document page
November 12, 2009 12:29pm
  • #1 / Nov 12, 2009 12:29pm
    DavSam
    Moderator’s note: Merged two threads. No need to double post.
    I need to create custom 404 error page.
    Right now Error message shows:
    “Not Found
    The requested URL /what.html was not found on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.”
    In Templates>Template Preferences, 404 Page is currently set to ‘None’
        Q1: What is FTP path to find file “thank_you” - located in /index.php/site/thank_you/
        Q2: After I copy & modify that file to become a 404 document, where do I place it to point to through Templates>Template Preferences>404 Page ?
  • #2 / Nov 12, 2009 2:34pm
    DavSam
    “Not Found
  • #3 / Nov 12, 2009 4:37pm
    serafico
    You can create your custom 404 page as any other template. Just create a template anywhere you want and than simply set that 404 template in your Global Template Preferences.
  • #4 / Nov 13, 2009 10:37am
    DavSam
    I do not know how to “create a template anywhere you want”. My questions are:
      Q1: I want to copy a certain file “thank_you” - located in /index.php/site/thank_you/ and modify it to be used as 404 Page. What is path to find/locate that file?
      Q2: Then where do I put that modified-to-be-404 Page file so that it shows up as option to point to from Templates>Template Preferences>404 Page ?
