I’ve got one new blogger who can only file using a blackberry… Does Expression Engine have a good and reliable means for him to do that?
October 15, 2009 7:06pm
Subscribe [2]#1 / Oct 15, 2009 7:06pm
#2 / Oct 15, 2009 7:44pm
Hi mickfealty-
There a few paths you could take on this one.
1) Find a Blackberry app that uses the Metaweblog API, and update posts that way. Detailed info on this API can be found here: http://expressionengine.com/docs/modules/metaweblog_api/index.html
2) You could also create A SAEF (Stand-Alone Entry Form), and format it for the Blackberry, and have them add entries that way. More info on SAEF here: http://expressionengine.com/docs/modules/weblog/entry_form.html
3) Lastly, you could try using the Moblog Module, since it uses email to add entries, and a Blackberry can definately handle that type of entry. More info on the Moblog Module here: http://expressionengine.com/docs/modules/moblog/index.html
Let us know if this helps you out. Thanks!
