Hello,
I have a reseller account for my personal domains and before buying MSM I just asked my host, asmallorange.com [ASO], if that expansion would work in their shared servers, and this is what they said:
“Yes, it is possible to use that expansion [MSM] if sub-domains need to be able to access your main installation directory.”
As you can see they were talking only about sub-domains, so I asked again specifically about domains, and here it is what they replied:
“If you are wanting a cPanel account located at /home/account1/public_html/ to be able to access the files of another cPanel account located at /home/account2/public_html/ then no, that will not work do to permission restrictions.”
Since cPanel is very common and ASO doesn’t use esoteric* server configurations, I’m sure there should be a way to have MSM working on this environment.
Thank you for any help,
Abraham
* I said that because time ago I had a customer with all his sites hosted on a Windows server on GoDaddy… Just a nightmare.
