Control Panel Settings Not Saving
October 01, 2009 12:51am
  • #1 / Oct 01, 2009 12:51am
    Devon Shaw
    To start, I’ve gone through this thread:
    http://ellislab.com/forums/viewthread/89133/
    and this one:
    http://ellislab.com/forums/viewthread/97987/
    and am still having issues. Same thing as the users above. Upgraded from 1.5.2 and now certain control panel settings (not all of them, oddly) aren’t sticking. Most notably “Default CP Theme”, “Publish Tab Behavior”, and “Use Category URL Titles in Links.” I’ve checked the following:
    - config.php and config_bak.php are set at 666.
    - attempted to resolve by changing /system/ to 777, didn’t work, changed it back.
    - issue doesn’t resolve no matter which admin_session_type setting I manually change in config.php.
    - attempted to re-upload cp.admin.php in forced ASCII transfer.
    - attempted to re-upload default cp theme.
    I’m at a loss after a very frustrating evening of upgrades, particularly since I’m saddled with over a decade of database material that I can’t simply wipe and start from scratch. This isn’t the only lingering issue, but for now it’s the most important one.
  • #2 / Oct 01, 2009 1:43am
    Devon,
    What do you have in your config.php file at the moment?
    Before posting remember to edit out any sensitive information like usernames and passwords.
    After your upgrade did you manually clear your cache?
    FTP into system/cache and delete everything inside of it including the folders. Leave index.html intact.
  • #3 / Oct 01, 2009 2:01am
    Devon Shaw
    Cleared the cache manually every time I tried one of the above tricks. Here’s my config.php (beware, it’s long):
    <?php
    if ( ! defined('EXT')){
    exit('Invalid file request');
    $conf['app_version'] = "168";
    $conf['license_number'] = "0000-0000-0000-0000";
    $conf['debug'] = "1";
    $conf['install_lock'] = "1";
    $conf['db_hostname'] = "mysql.mysite.com";
    $conf['db_username'] = "";
    $conf['db_password'] = "";
    $conf['db_name'] = "";
    $conf['db_type'] = "mysql";
    $conf['db_prefix'] = "exp";
    $conf['db_conntype'] = "0";
    $conf['encryption_type'] = "sha1";
    $conf['system_folder'] = "system";
    $conf['cp_url'] = "http://www.mysite.com/system/";
    $conf['site_index'] = "";
    $conf['site_name'] = "My Site";
    $conf['site_url'] = "http://www.mysite.com/";
    $conf['theme_folder_url'] = "http://www.mysite.com/themes/";
    $conf['doc_url'] = "http://eedocs.pmachine.com/";
    $conf['webmaster_email'] = "[email protected]";
    $conf['webmaster_name'] = "Webmaster";
    $conf['weblog_nomenclature'] = "section";
    $conf['max_caches'] = "300";
    $conf['captcha_url'] = "http://www.mysite.com/images/captchas/";
    $conf['captcha_path'] = "/home/mysite/images/captchas/";
    $conf['captcha_font'] = "y";
    $conf['captcha_rand'] = "y";
    $conf['captcha_require_members'] = "n";
    $conf['enable_db_caching'] = "n";
    $conf['enable_sql_caching'] = "n";
    $conf['force_query_string'] = "n";
    $conf['show_queries'] = "n";
    $conf['template_debugging'] = "n";
    $conf['include_seconds'] = "n";
    $conf['cookie_domain'] = "";
    $conf['cookie_path'] = "";
    $conf['cookie_prefix'] = "";
    $conf['user_session_type'] = "c";
    $conf['admin_session_type'] = "cs";
    $conf['allow_username_change'] = "y";
    $conf['allow_multi_logins'] = "y";
    $conf['password_lockout'] = "y";
    $conf['password_lockout_interval'] = "1";
    $conf['require_ip_for_login'] = "y";
    $conf['require_ip_for_posting'] = "y";
    $conf['allow_multi_emails'] = "n";
    $conf['require_secure_passwords'] = "n";
    $conf['allow_dictionary_pw'] = "y";
    $conf['name_of_dictionary_file'] = "";
    $conf['xss_clean_uploads'] = "y";
    $conf['redirect_method'] = "redirect";
    $conf['deft_lang'] = "english";
    $conf['xml_lang'] = "en";
    $conf['charset'] = "utf-8";
    $conf['send_headers'] = "y";
    $conf['gzip_output'] = "n";
    $conf['log_referrers'] = "y";
    $conf['max_referrers'] = "500";
    $conf['is_system_on'] = "y";
    $conf['time_format'] = "us";
    $conf['server_timezone'] = "UM8";
    $conf['server_offset'] = "";
    $conf['daylight_savings'] = "y";
    $conf['default_site_timezone'] = "";
    $conf['default_site_dst'] = "n";
    $conf['honor_entry_dst'] = "y";
    $conf['mail_protocol'] = "mail";
    $conf['smtp_server'] = "";
    $conf['smtp_username'] = "";
    $conf['smtp_password'] = "";
    $conf['email_debug'] = "n";
    $conf['email_charset'] = "utf-8";
    $conf['email_batchmode'] = "n";
    $conf['email_batch_size'] = "";
    $conf['mail_format'] = "plain";
    $conf['word_wrap'] = "y";
    $conf['email_console_timelock'] = "5";
    $conf['log_email_console_msgs'] = "y";
    $conf['cp_theme'] = "default";
    $conf['email_module_captchas'] = "n";
    $conf['log_search_terms'] = "y";
    $conf['un_min_len'] = "2";
    $conf['pw_min_len'] = "5";
    $conf['allow_member_registration'] = "y";
    $conf['allow_member_localization'] = "y";
    $conf['req_mbr_activation'] = "email";
    $conf['new_member_notification'] = "n";
    $conf['mbr_notification_emails'] = "";
    $conf['require_terms_of_service'] = "y";
    $conf['use_membership_captcha'] = "n";
    $conf['default_member_group'] = "5";
    $conf['profile_trigger'] = "member";
    $conf['member_theme'] = "default";
    Continued…
  • #4 / Oct 01, 2009 2:02am
    Devon Shaw
    $conf['enable_avatars'] = "y";
    $conf['allow_avatar_uploads'] = "y";
    $conf['avatar_url'] = "http://www.mysite.com/images/avatars/";
    $conf['avatar_path'] = "/home/mysite/images/avatars/";
    $conf['avatar_max_width'] = "100";
    $conf['avatar_max_height'] = "100";
    $conf['avatar_max_kb'] = "70";
    $conf['enable_photos'] = "y";
    $conf['photo_url'] = "http://www.mysite.com/images/member_photos/";
    $conf['photo_path'] = "/home/mysite/images/member_photos/";
    $conf['photo_max_width'] = "250";
    $conf['photo_max_height'] = "250";
    $conf['photo_max_kb'] = "150";
    $conf['allow_signatures'] = "y";
    $conf['sig_maxlength'] = "500";
    $conf['sig_allow_img_hotlink'] = "n";
    $conf['sig_allow_img_upload'] = "n";
    $conf['sig_img_url'] = "http://www.mysite.com/images/signature_attachments/";
    $conf['sig_img_path'] = "/home/mysite/images/signature_attachments/";
    $conf['sig_img_max_width'] = "480";
    $conf['sig_img_max_height'] = "80";
    $conf['sig_img_max_kb'] = "30";
    $conf['prv_msg_upload_path'] = "/home/mysite/images/pm_attachments/";
    $conf['prv_msg_max_attachments'] = "3";
    $conf['prv_msg_attach_maxsize'] = "250";
    $conf['prv_msg_attach_total'] = "100";
    $conf['prv_msg_html_format'] = "safe";
    $conf['prv_msg_auto_links'] = "y";
    $conf['prv_msg_max_chars'] = "6000";
    $conf['site_404'] = "";
    $conf['save_tmpl_revisions'] = "n";
    $conf['max_tmpl_revisions'] = "5";
    $conf['save_tmpl_files'] = "y";
    $conf['tmpl_file_basepath'] = "/home/mysite/system/template_files/";
    $conf['secure_forms'] = "y";
    $conf['deny_duplicate_data'] = "y";
    $conf['redirect_submitted_links'] = "n";
    $conf['enable_censoring'] = "n";
    $conf['censored_words'] = "";
    $conf['censor_replacement'] = "";
    $conf['banned_ips'] = "";
    $conf['banned_emails'] = "";
    $conf['banned_usernames'] = "";
    $conf['banned_screen_names'] = "";
    $conf['ban_action'] = "bounce";
    $conf['ban_message'] = "";
    $conf['ban_destination'] = "http://www.yahoo.com/";
    $conf['enable_emoticons'] = "y";
    $conf['emoticon_path'] = "http://www.mysite.com/images/smileys/";
    $conf['recount_batch_total'] = "1000";
    $conf['enable_image_resizing'] = "y";
    $conf['image_resize_protocol'] = "gd2";
    $conf['image_library_path'] = "";
    $conf['thumbnail_prefix'] = "thumb";
    $conf['word_separator'] = "underscore";
    $conf['use_category_name'] = "n";
    $conf['reserved_category_word'] = "category";
    $conf['auto_convert_high_ascii'] = "n";
    $conf['new_posts_clear_caches'] = "y";
    $conf['auto_assign_cat_parents'] = "y";
    $conf['remap_pm_urls'] = "n";
    $conf['remap_pm_dest'] = "";
    $conf['new_version_check'] = "y";
    $conf['publish_tab_behavior'] = "hover";
    $conf['enable_throttling'] = "n";
    $conf['banish_masked_ips'] = "y";
    $conf['max_page_loads'] = "10";
    $conf['time_interval'] = "8";
    $conf['lockout_time'] = "30";
    $conf['banishment_type'] = "message";
    $conf['banishment_url'] = "";
    $conf['banishment_message'] = "You have exceeded the allowed page load frequency.";
    $conf['enable_search_log'] = "y";
    $conf['max_logged_searches'] = "500";
    $conf['allow_extensions'] = "y";
    $conf['mailinglist_enabled'] = "y";
    $conf['mailinglist_notify'] = "n";
    $conf['mailinglist_notify_emails'] = "";
    $conf['memberlist_order_by'] = "total_posts";
    $conf['memberlist_sort_order'] = "desc";
    $conf['memberlist_row_limit'] = "20";
    $conf['forum_is_installed'] = "y";
    $conf['forum_trigger'] = "board";
  • #5 / Oct 01, 2009 2:05am
    Devon,
    K quick test for you. If you comment out ‘$conf[‘cp_theme’] = “default”;’ in your config file, are you able to get the relevant change to stick in the CP now?
  • #6 / Oct 01, 2009 2:24am
    Devon Shaw
    Yes, it does.
  • #7 / Oct 01, 2009 2:45am
    Devon,
    From 1.6 onwards nearly all of those config variables have been added to the actual database, so you can scale back a lot of what you have there.
    By all means backup whatever you have in there first.
    Here is a sample config.php for EE v1.6.0.
    EE Wiki : Config.php for v1.6.0
    In addition to that add in some forum config variables
