403 Directory Access Is Forbidden after upgrade to 1.6.8
September 30, 2009 9:34pm
  • #1 / Sep 30, 2009 9:34pm
    Devon Shaw
    I just upgraded an ancient installation of EE 1.5.2 to 1.6.8 and am now failing to get any output whatsoever.
    The main page serves blank, /master/ (the renamed system directory) spits out Error 403 Directory Access Is Forbidden. It is also giving me the same error message on other EE-specific directories like /images/. I diligently went back to check that all my file permissions are set at 644, that directories are 755, and that /system/cache/ is 777. The install had the usual rewrite conditions removing index.php in htaccess, I have completely removed the whole file and still no luck. This is the same host, the same directory, no migration whatsoever. What is going on?
    PS: EE successfully updated incrementally from 1.5.2 to 1.6, then each point upgrade thereafter. Update appears to believe it completed successfully.
  • #2 / Oct 01, 2009 12:37am
    Devon Shaw
    Resolved, but issue undetermined. I basically just installed the default files for 1.6.8 completely and ported over all my old stuff.
  • #3 / Oct 01, 2009 1:44am
    Devon,
    what do you mean by ported?
  • #4 / Oct 01, 2009 1:52am
    Devon Shaw
    I cherry-picked all my user-level content—plugins, templates, images, themes and files—and moved them to their respective places in a completely new installation, as opposed to copying over critical directories as the update process typically entails.
  • #5 / Oct 01, 2009 2:47am
    Devon,
    As you have resolved the issue yourself this will be quite hard to troubleshoot but to make sure you have the most recent set of files up there, can you download a fresh copy of EE and run through a typical build update.
    EE Docs : Updating ExpressionEngine to the Latest Build
