issues with SQL query and the form element, using GET
September 28, 2009 6:09pm
Subscribe [4]
  • #1 / Sep 28, 2009 6:09pm
    Pat Brumfield
    Greetings,
    Thanks to some helpful users on the forums, i’ve been able to get some custom advanced search/filtering working on my site. The problem is that while the search works with using the method of POST on my form html element, when I try to change it to GET (to show the search string in the URL so users can save it), the search no longer works. Here are some examples:
    working, with POST: http://www.daybreakutah.com/homes/
    not working, with GET: http://www.daybreakutah.com/test/homes/
    The items that are different on the GET version are the method=“GET” on the form element, and i’ve changed the way I retrieve the variables when building my SQL query. Example:
    <?php
    $buildsql = "SELECT * FROM `exp_weblog_data` WHERE `weblog_id` = '1'";
    // builder
    $b = @$_GET['builder'];
    $bsql = NULL;
    if ($b == 0) { $bsql = "`field_id_9` IS NOT NULL"; }
    if ($b == 1) { $bsql = "`field_id_9`='Bangerter Homes'"; }
    if ($b == 2) { $bsql = "`field_id_9`='Destination Homes'"; }
    if ($b == 3) { $bsql = "`field_id_9`='Garbett Homes'"; }
    if ($b == 4) { $bsql = "`field_id_9`='Gold Medallion Homes'"; }
    if ($b == 5) { $bsql = "`field_id_9`='Hamlet Homes'"; }
    if ($b == 6) { $bsql = "`field_id_9`='Holmes Homes'"; }
    if ($b == 7) { $bsql = "`field_id_9`='Ivory Homes'"; }
    if ($b == 8) { $bsql = "`field_id_9`='Liberty Homes'"; }
    if ($b == 9) { $bsql = "`field_id_9`='Rainey Homes'"; }
    if ($b == 10) { $bsql = "`field_id_9`='Richmond American Homes'"; }
    $buildsql = $buildsql." AND $bsql ";
    As you can see on the second link above, none of the selections from the form are being carried over to the search results page (i am printing out the SQL query on that page for testing). Any hints as to why POST would work, but GET wouldn’t?
    Thanks for your help!
    Pat
  • #2 / Sep 28, 2009 7:34pm
    Greg Aker
    $_GET can be a security issue if things are improperly escaped.  Try the input class, specifically:
    <?php
    global $IN;
    $foo = $IN->GBL('foo', 'GET'));
    -greg
  • #3 / Oct 02, 2009 6:26pm
    Pat Brumfield
    thanks Greg, i’ll give the input class a go.
    cheers
  • #4 / Oct 02, 2009 7:13pm
    Pat Brumfield
    Greg, I can get the input class working if i set everything to POST, but trying to access the data via GET brings in an empty set. Any thoughts or a direction to send me in?
    Thanks again.
    Pat
  • #5 / Oct 03, 2009 8:43pm
    Pat,
    Do you have your templates PHP set on input or output?
  • #6 / Oct 05, 2009 4:45pm
    Pat Brumfield
    hi john, i have two templates in use:
    - the actual html search form, which has PHP set to output
    - the search results page, which also includes the PHP code to create the SQL query and run it, which has PHP set to input
    i have yet to update this EE install to 1.6.8 yet, could that have something to do here?
    thanks
  • #7 / Oct 05, 2009 5:14pm
    You could certainly try to upgrade to the latest version and build. It’s a recommended update and would help us to rule out file corruption as well.
  • #8 / Oct 06, 2009 12:39pm
    Pat Brumfield
    ok, install updated to 1.6.8, still not able to get the GET method working. any other thoughts out there?
  • #9 / Oct 06, 2009 3:18pm
    Pat Brumfield
    ok, i created a local install to test the code, and it appears to be an extension/plugin/module conflict, as I can get method=“get” working locally. here is a list of what I have installed on the non-working server version. any thoughts as to where the conflict could be?
    Extensions
    JQuery for Control Panel
    LG Add Sitename
    LG TinyMCE
    LG .htaccess
    LG Better Meta
    File (Mark Huot)
    User
    Checkbox
    Favorites Extension
    FieldFrame
    Plugins
    Character Limiter
    Magpie RSS Parser
    Randomizer
    Word Limiter
    XML Encode
    LG Better Meta
    Image Sizer
    Custom Drop Down
    Modules
    Favorites
    Mailling List
    Member
    Pages
    Query
    Referrer
    RSS
    Search
    Statistics
    Trackback
    User
    Section
  • #10 / Oct 06, 2009 3:32pm
    I would start by disabling all of your extensions, globally (settings are kept that way). See if that resolves the issue, if it does you’ll need to test them one by one to see which one triggers the problem.
  • #11 / Oct 06, 2009 5:21pm
    Pat Brumfield
    disabling the extensions did not solve the problem. should i also look into disabling plugins and modules?
  • #12 / Oct 06, 2009 5:24pm
    Yes, you can try to remove the plugins from your templates / site, via the plugin manager. Basically, what’s the difference between your live site and the setup at home? Any of these differences could be to blame.
  • #13 / Oct 06, 2009 7:45pm
    Pat Brumfield
    i went through and disabled all extensions/modules/plugins to match the bare-bones install on my local machine. i still am unable to retrieve the string produced by the GET form. any other thoughts as to why this is occurring?
    i’m going to look to replicate the functionality i need another way, although i’m almost certain that if method=“GET” would work, that’d be exactly what I need.
    thanks for your help
  • #14 / Oct 06, 2009 7:58pm
    Pat, what about differences in PHP versions?
  • #15 / Oct 07, 2009 3:34am
    Pat Brumfield
    Hi Sue. I ruled out PHP version differences by writing a simple form method=“GET” routine, and uploading it to the same server (outside of my EE install though). it works fine, so I isolated the issue to only occurring within the EE “walls”. i’ve worked out another solution for this particular problem, although it’s still puzzling why GET isn’t working here…
    cheers
    pat
