Entries displaying twice?
September 17, 2009 5:13pm
  • #1 / Sep 17, 2009 5:13pm
    techops
    I can’t figure out why my page is displaying my content twice. I have the limit set but it seems to ignore that. I am using similar code on another site and it seems to work just fine. I can’t understand why this would have a problem.
    My URL structure is: http://www.mysite.com/{cat_url_title}/{url_title}/
    Here’s my code:
    {if segment_1 != "" AND segment_2 != ""}
            {exp:query sql="SELECT cat_id FROM exp_categories WHERE cat_url_title = '{segment_1}'"}
                {exp:weblog:entries weblog="store_products" limit="1" url_title="{segment_2}" disable="trackbacks|pagination|member_data" }
                    <div class="grid_3 alpha productImage">
                        <a href="#">{prod_image}</a>
                    </div>
                    <div class="grid_10 omega">
                        {title}
                   </div>
                {/exp:weblog:entries}
            {/exp:query}
    Any thoughts would be greatly appreciated.
  • #2 / Sep 17, 2009 5:19pm
    What version and build are you using? Do you’ve got a link? To be honest, I am not entirely following your code: You are querying “cat_id” without using it again? What’s the purpose of your setup here?
  • #3 / Sep 17, 2009 5:25pm
    techops
    Build:  20090723
    Please excuse the lack of design to the page, I’m working on the programming first.
    Here’s the page having the problem:
    http://techmark.webfactional.com/books/devo2go_audio_devotional/
    I’m following the tips from this entry here:
    http://fortysevenmedia.com/blog/archives/setting_up_custom_category_url_structures_in_expressionengine/
    to set up my “custom” url structure based off the categories.
    When I say I’ve done this before, is that on: http://www.outreachpublishing.com/ I did the similar set up in a template group, but this time I want to have it one level higher and remove the “products” from the URL and have it off the root.
    Am I making sense?
  • #4 / Sep 17, 2009 5:26pm
    techops
    maybe the sql query is throwing it off?
    EDIT: yep, that was it! sorry about all that 😊
  • #5 / Sep 17, 2009 5:31pm
    So, you’re all set for now, then?
