At first, I thought I was having the same issues as noted in this thread:
http://ellislab.com/forums/viewthread/127701/
Then I followed the steps to make sure I was doing everything it stated, and I was.
Here is what is happening:
1. I put a fresh install of EE on Windows IIS (yeah, I know ...), and it seemed to be working for the most part. I was using the default theme. I posted a new weblog entry, and it displayed on the homepage.
2. I have uninstalled/reinstalled so many times that I decided to try to make a minor change to the site index by adding the word ‘Tada!’ right below the beginning body tag. I saved it, viewed the homepage, and there it was.
3. For some reason, after I make that first edit, no other edits will display on the homepage of the site through that homepage address (http://gjsd.net/beta/). Only that initial edit to the template will display there.
4. This was working before, but any additional updates I made to the same template would only display on http://gjsd.net/beta/index.php/site/index.php (notice that I have to include the final index.php for anything to display at all). Now, unfortunately, neither template is showing any updates. (Edited: Ok, this is showing an update I made over an hour ago [displaying one post], not what the template actually should be showing [the default index template with no edits].)
Things I have tried:
1. Forced url query strings from the control panel and by editing the index.php file. Tried tried one, turned it off. Tried the other, turned it off. Tried both together. Tried none. Nothing has changed.
2. I am not removing index.php from the urls by any means prior to or during this process.
3. I am using the default set up without any changes to anything other than mentioned above.
4. I am on a Windows server with all necessary components installed to run EE.
I’m at a loss as to what this error would be called to even try to search for it. I tried a variety of things, but I’m stumped. Yes, I’m new-ish to EE, but this is something I’ve never encountered.
