Basic Query Module functionality not working
August 31, 2009 11:45am
  • #1 / Aug 31, 2009 11:45am
    philfreo
    I’ve got a full version of EE 1.6.8 (build 20090723) installed, the Query module activated, yet the basic functionality is not working for me.  My template is simply:
    {exp:query sql="SELECT cat_id FROM exp_categories"}
    {cat_id}
    {if no_results}no results!{/if}
    {exp:query}
    Yet the page outputs:
    {cat_id}
    rather than the actual cat_id’s from the database.
    I know that the Query module is at least somewhat working because I edited mod.query.php (for testing) after line 182 and added:
    print_r($query);
    And on the outputted template I do indeed get the full result set.
    DB_Cache Object
        [result] => Array
                [0] => Array
                        [cat_id] => 4
                [1] => Array
                        [cat_id] => 5
                [2] => Array
                        [cat_id] => 6
                [3] => Array
                        [cat_id] => 7
                [4] => Array
                        [cat_id] => 8
                [5] => Array
                        [cat_id] => 9
                [6] => Array
                        [cat_id] => 10
        [row] => Array
                [cat_id] => 4
        [num_rows] => 7
        [q_count] => 18
        [fields] => Array
    What could be stopping the template tags from being parsed correctly?  I’ve got no other problems with tags on the rest of my site.
  • #2 / Aug 31, 2009 12:19pm
    First things first. How about upgrading your version of EE? You’re quite a few builds behind.
  • #3 / Aug 31, 2009 12:28pm
    philfreo
    That was a typo.  I’m running the latest build of 1.6.8.
  • #4 / Aug 31, 2009 1:18pm
    Derek Jones
    You’re missing the forward slash from your closing tag:
    {cat_id}
    {exp:query}
    Should be (notice the last line):
    {cat_id}
    {/exp:query}
  • #5 / Aug 31, 2009 2:04pm
    philfreo
    {cat_id}
    {exp:query}
    {cat_id}
    {/exp:query}
    Wow, duh!  This was driving me crazy.  I knew it had to be something stupid but sometimes it takes a second pair of eyes.  Thanks!
    It would be nice for EE to output some error message if basic parsing fails.
  • #6 / Aug 31, 2009 2:33pm
    Derek Jones
    If you turn on the Template Debugging (Output and Debugging Preferences) you would indeed get such a message, e.g.:
    (0.013598) Tag: {exp:query sql="SELECT cat_id FROM exp_categories"}
    (0.013719) No Closing Tag
    (0.013776) Tag: {exp:query}
    (0.013816) No Closing Tag
  • #7 / Aug 31, 2009 2:36pm
    philfreo
    Excellent, thanks.
  • #8 / Aug 31, 2009 2:49pm
    Derek Jones
    Glad to help, Phil!
