Having some trouble with the search module
August 18, 2009 3:51pm
  • #1 / Aug 18, 2009 3:51pm
    oniracom
    {exp:search:simple_form weblog="news" search_in="entries" result_page="/search/results"}
                            <input type="text" name="keywords" id="keywords" value="{exp:search:keywords}" /><input type="submit" value="search" class="submit btn" >
                        {/exp:search:simple_form}
    This code is on my results page, because I want a search box for them to easily search again.  The problem is that {exp:search:keywords} is not showing up as the term searched, but instead the encrypted version of it, for example: M00o93H7pQ09L8X1t49cHY01Z5j4TT91fGfr
    If I move {exp:search:keywords} outside of the {exp:search:simple_form} then it correctly displays the search term.  This code has been copied from another site where it works fine, so what am I missing?
  • #2 / Aug 18, 2009 3:55pm
    That’s not encrypted, it’s a marker that should be replaced by EE. What version and build of EE are you running? Do you’ve got a link? Any third-party extensions enabled?
  • #3 / Aug 18, 2009 5:25pm
    oniracom
    thanks for the quick response.  we’re using EE 1.6.7.  I dont think we’re using any interfering extensions.
    FieldFrame (v.1.2.1)
    LG Add Sitename (v.1.2.0)
    Hidden Weblogs (v.1.0.1)
    Edit Tab AJAX (v.1.2.1) )
    Twomile Login Redirect (v.1.1.0)
    User (v.2.0.7)
    LG Data Matrix (v.1.1.1)
    Advanced Captcha (v.1.0.2)
    jQuery for the Control Panel (v.1.1.1)
    Playa (v.1.3.3)
    File_Gears_ext (v.1.0.0)
    Clone Entries (v.1.1)
    LG Member List (v.1.2.1)
    Text: Improved (v.1.0.3)
    File, by Mark Huot (v.3.1.2)
    Fresh Variables (v.1.0)
    Geo Coordinates (v.1.0.3)
    Filter By Author (v.1.0)
    Tag Submit (v.2.6.4)
    Tab Forward (v.1.1)
    Edit Menu (v.1.0.2)
    Edit Remember (v.1.1.0)
    LG Addon Updater (v.1.0.2)
    LG FirePHP (v.1.0.0)
    LG Social Bookmarks (v.2.0.2)
    Simplify Edit Table (v.1.1)
    Custom Fields in EE Tags (v.2.1.4)
    Publishers Clearinghouse (v.1.2)
    solutionsfordreamers.com/search
    search for ‘google’ and you’ll get a result.
  • #4 / Aug 18, 2009 5:45pm
    I think you are running into this issue. Please see the wiki article for a working solution, I don’t think it has to be a hidden field.
  • #5 / Aug 18, 2009 5:55pm
    oniracom
    hmm, thanks.
  • #6 / Aug 18, 2009 5:56pm
    Let us know how it goes, or if that takes care of the issue for you.
