I am trying to change the styles for the wiki theme I am using, but any changes I make to the theme php file refuse to show up on the page. I’m trying to add a custom class for floating images, but the changes just won’t go through. I’ve even deleted the entire theme file and saved it, but no matter what I do, I can’t seem to edit the dang file and have it stick. Is there some setting somewhere that needs to be changed? I duplicated the default theme folder and renamed it, and I’ve confirmed that the wiki is actually using that theme. Still no luck. Does anyone know what might be causing this?
Also, is there a simple way to do things like float an image in the wiki? I tried using the textile syntax, but that didn’t work either. With MediaWiki, there is a simple way to set floats for images, but EE wiki doesn’t seem to have this functionality, so all images inserted into an article are styled as inline by default, which looks quite ugly. I’d appreciate any help. Thanks.
[Mod Edit: Moved to the Technical Support forum]
