Control Panel is blank, please help.
August 11, 2009 2:14pm
  • #1 / Aug 11, 2009 2:14pm
    wecreateyou
    I’m running 1.6.8
    Everything was working fine and installed LG Better Meta 1.8.0
    Next I tried to navigate to another page in the control panel and everything went blank.
    I don’t have access to the control panel now to try and fix it so I deleted the Lg stuff via FTP module, extension, plugin. I aslo found the LG stuff in the database and deleted that using MyPhpAdmin. Still seeing nothing.
    How can I get the control panel back asap.
    Thanks in advance.
  • #2 / Aug 11, 2009 2:35pm
    wecreateyou
    BTW, The front end of the site is working by the way it’s only the control panel that is blank.
  • #3 / Aug 11, 2009 4:28pm
    You can try turning extensions off globally by adding this to your config.php:
    $conf['allow_extensions'] = "n";
  • #4 / Aug 11, 2009 8:14pm
    wecreateyou
    Thanks Ingmar,
    I did eventually figure that part out and it did allow me back into the CP…
    The problem I’m still having is how to remove the offending extension so I can enable the working ones.
    When I delete the extension manually I get this error.
    MySQL ERROR:
    Error Number: 1146
    Description: Table 'my_database_name.exp_lg_better_meta' doesn't exist
    Query: ALTER TABLE `exp_lg_better_meta` CHANGE `index` `index` VARCHAR( 1 ) NOT NULL, CHANGE `follow` `follow` VARCHAR( 1 ) NOT NULL, CHANGE `archive` `archive` VARCHAR( 1 ) NOT NULL
    I just need to delete the extension so I can start over but it’s not working,
    Thanks again
  • #5 / Aug 11, 2009 8:19pm
    Greg Aker
    how are you trying to delete the extensions manually?  Do you ahve the extension files on your server?
    -greg
  • #6 / Aug 11, 2009 8:28pm
    wecreateyou
    Yes, I just deleted it via my FTP client after I used the config file to disable them all.
    Thanks Greg
  • #7 / Aug 11, 2009 9:06pm
    Greg Aker
    Did you uninstall the extension in the control panel first?
    -greg
  • #8 / Aug 11, 2009 9:51pm
    wecreateyou
    Unfortunately I didn’t get a chance, I wasn’t able to get into the CP when the initial problem occurred.
    Deleting via ftp was how I attempted to fix the problem, which of course made it worse. Next, I thought about disabling all extensions through the config file. That helped get me in the CP but by that time I had screwed up already. I now have to have all extensions disabled to get in the CP.
    Here’s a scenario:
    If I disable the extensions I can get into the CP.
    If I enable all extensions with the offending extension present I get a DB error.
    If I remove the offending extension I can’t gt into the CP
    Any Ideas?
  • #9 / Aug 11, 2009 9:55pm
    Greg Aker
    okay, here’s what to try:
    log into your control panel, and go to the extensions page.  Upload the offending extension.  Reload the extensions page & let’s see if it errors out.  If it doesn’t, go ahead and uninstall the extension.
    -greg
  • #10 / Aug 11, 2009 10:14pm
    wecreateyou
    Here’s are the steps I took.
    1. I disabled extensions using the config file. (only way into CP at this time)
    2. I went to the extensions page.
    3. I re-uploaded the extension.
    4. I reloaded extensions page and enabled all extensions.
    Here’s the error I received:
    MySQL ERROR:
    Error Number: 1060
    Description: Duplicate column name 'priority'
    Query: ALTER TABLE exp_lg_better_meta ADD `priority` VARCHAR( 5 ) NOT NULL , ADD `change_frequency` VARCHAR( 50 ) NOT NULL , ADD `include_in_sitemap` VARCHAR( 1 ) NOT NULL
  • #11 / Aug 11, 2009 10:45pm
    wecreateyou
    What do you think would happen if I deleted the lg_better_meta table from the database?
  • #12 / Aug 11, 2009 10:56pm
    If you look in exp_extensions, do you see mention of that extension?
  • #13 / Aug 11, 2009 11:15pm
    wecreateyou
    Yes Lisa, It’s in the exp_extensions table on the second page.
  • #14 / Aug 11, 2009 11:18pm
    wecreateyou
    After paging through the table I found over 90 mentions of the extension, that’s not normal is it?
  • #15 / Aug 11, 2009 11:22pm
    I’ve never used the extension so I can’t answer that.  You might contact LG at this point about how to fully clean it up safely.
    Or.. do you have a backup?
