[PLUGIN] DashLower - converts spaces in a string to dashes '-' and makes it lowercase (handy for urls)
August 02, 2009 10:15pm
Subscribe [5]
  • #1 / Aug 02, 2009 10:15pm
    KomodoDave
    (I’m developing locally and don’t have a license yet, so can’t post in the plugins section..)
    <?php
    $plugin_info = array(
      'pi_name' => 'DashLower',
      'pi_version' => '1.0',
      'pi_author' => 'N David Brown',
      'pi_author_url' => 'http://www.buildingfrombelow.org/',
      'pi_description' => 'Replaces spaces with dashes, and converts a string to lowercase',
      'pi_usage' => DashLower::usage()
    class DashLower
      function DashLower()
          global $TMPL;
          $this->return_data = strtolower(str_replace(' ', '-', $TMPL->tagdata));
      //  Plugin Usage
      // This function describes how the plugin is used.
      //  Make sure and use output buffering
      function usage()
      ob_start();
        {exp:dashlower}your_text{/exp:dashlower}
      <?php
      $buffer = ob_get_contents();
      ob_end_clean();
      return $buffer;
    Save it as pi.dashlower.php in your plugins dir, then use it like
    {exp:dashlower}{workProject}{/exp:dashlower}
  • #2 / Oct 31, 2009 10:54pm
    [/root.]
    Thanks. Really useful plugin.
  • #3 / Nov 01, 2009 3:54am
    Matthew Pennell
    You’ll also want to remove any non-standard characters from the string as well, if it’s intended for use as URLifying words:
    $this->return_data = str_replace(' ', '-', strtolower(preg_replace("/[^a-zA-Z0-9\s]/", "", $TMPL->tagdata)));
  • #4 / Nov 01, 2009 4:39am
    Also not everyone uses - as the separator. The default is underscore _.
    if ($PREFS->ini('word_separator') == 'dash')
    Look at mod.moblog.php around 3180.
