I have a map which will be divided into several clusters. Each cluster will be marked with a red dot. That dot needs to be resized dynamically (bigger or smaller) according to it’s value. I have attached image for reference. Now, the way I would approach this problem…
- Create weblog with categories for each cluster
- Custom weblog field: Drop-down List with options from 1-10 (1 for Min and 10 for Max size)
I assume that I need to put this data to XML file and link it to Flash file. Here I come to a dead end as I have never done something similar and I would need some help from you guys.
I would be grateful for any advice, link, tutorial or other kind of assistance.
Also, if any one could do this for me, they can send me PM.
