Hey all.
I’m having a similar problem to the the one I was having here and considering how helpful everyone was last time I’m hoping for another EEForum success story!
Here’s the basics..
As before, I’m calling magpie in a template that parses php on output.
Everything is working great… UNLESS… an item in the feed has a curly brace in it.
Then it breaks.
I’m using a custom function to parse the feed data before trying to use it (ie. the solve from the previous problem).
Figured I could just add the curly brace to the list of replaced characters but no luck.
Here’s the code…
class Xml_encode_tl {
var $return_data;
function Xml_encode_tl($str = '')
global $TMPL;
$this->return_data = '';
if ($str == '')
$str = $TMPL->tagdata;
$this->return_data = trim(str_replace('$', '$', $str));
$this->return_data = trim(str_replace('{', '{', $str));
$this->return_data = trim(str_replace('}', '}', $str));
}... but it’s not working.
Here’s the page in question… http://phishtwit.com
NOTE: I suppressed the feed from including the person who’s been using curly braces so it should appear to be working correctly.
Any help GREATLY appreciated.
TL
