Send monthly newsletter containing weblog entries to subscribers
July 17, 2009 5:05pm
  • #1 / Jul 17, 2009 5:05pm
    Ambition
    Hi Guys,
    I’m in discussions with a client that would like to send out a monthly newsletter containing content from a weblog. The content is a list of used cars. The client will be adding cars on a regular basis. In an ideal world, the client would like to set a status of ‘hot’ (or something similar) when adding a car, then at the end of each month, send out an email with an opening welcome message followed by a list of all of the cars marked as ‘hot’ to a mailing list.
    Is this achievable? I’ve produced a number of sites for various agencies using EE but this is the first time this functionality has been requested.
    I’ve taken a quick look at the Entry Mailing extension but as far as I can tell, I won’t give my client the opportunity to choose which entries to mail (via status or something similar) and when.
    Has anyone implemented a similar function to this? and if so, would you be kind enough to point me in the right direction.
    Look forward to hearing your thoughts.
    Gary 😊
  • #2 / Jul 17, 2009 5:48pm
    silenz
    Well, you could achieve at least something in that direction with Entry Mailing.
    Create a weblog for the newsletters. Whenever you want to send one start a new entry there or use an existing one and just re-mail it.
    Then use a regular template in which you pull the data you need. If you want to employ data not connected to the entry used for the mailing be sure to use dynamic=“off” in the weblog:entries:tag.
    {!-- This would use data of the entry used to initiate the mailing //--}
    {exp:weblog:entries}
    {text}
    {more}
    {/exp:weblog:entries}
    {!-- This can pull any kind of data defined by you //--}
    <ul>
    {exp:weblog:entries dynamic="off" weblog="cars" status="hot"}
    <li>{title}</li>
    </ul>
    I hope that was comprehensible…
  • #3 / Jul 18, 2009 5:16am
    Ambition
    Ah! Superb.
    I had noticed that you can assign a regular template to each Entry Mailing, but hadn’t considered creating a new section devoted to the newsletters and then assigning my template to that. Ha! It’s obvious now that you mention it. Sorry… had a long day yesterday 😉
    Nice one!
    G.
