.htaccess index.php removal PLUS 301 redirects
July 08, 2009 9:30am
Subscribe [4]
  • #1 / Jul 08, 2009 9:30am
    WDBookassist
    I’m using some fairly simple .htaccess to remove /index.php/ from my urls. This has worked fine for me until now.
    But I also now want to do some 301 redirects for old site urls that existed. I’m having trouble combining the two. Here’s my .htaccess file:
    RewriteEngine on
    # Everything else to the EE controller
    RewriteRule ^(.+)$ /index.php?/$1 [L]
    # A bunch of redirects
    Redirect 301 /rooms.php <a href="http://website.com/chambres/">http://website.com/chambres/</a>
    I’m going to need lots of redirects here, but I can’t get the first one working.
    When I try to visit http://website.com/rooms.php I am brought to
    http://website.com/chambres/?/rooms.php and don’t understand how it’s carrying the “rooms.php” across.
    (The 301 on its own works fine if I remove the index.php rewrite.)
    I had looked at other strategies for removing /index.php/ but I don’t think I can use them as I’m using a lot of pages and so have a lot of /page1/ /page2/ addresses, rather than /template/ as described in those approaches.
    Any ideas? My understanding of .htaccess is pretty basic.
  • #2 / Jul 08, 2009 1:15pm
    Manoj Thomas
    Hey Pierce, I haven’t checked to see if this works, but maybe try this out?
    RewriteEngine On
    rewriteRule ^rooms.php$ /chambres/ [R=301,L,NC]
    (Generally I remove the index.php last in my .htaccess)
    Hope this helps,
    Manoj
  • #3 / Jul 08, 2009 1:24pm
    WDBookassist
    Hi Manoj,
    Hey, that worked nicely. Thanks!
    I had already tried reordering the 301 and the index.php rewrite, but it wasn’t working with my original code. Your rewrite seems to be functioning perfectly.
    Thanks, really appreciate it.
    Pierce
  • #4 / Jul 08, 2009 1:27pm
    Manoj Thomas
    sweet!
  • #5 / Jul 22, 2009 7:22pm
    giovanni
    I have been trying in various ways to achieve the removal of “index.php” from my URLS but i have never succeeded.
    is that we need to also update the Path Settings info in our Weblog Administration ›  Weblog Management ›  Edit Weblog Preferences section??
    At the moment I have http://www.example.com/index.php/contact  Should we updating that and remove the “index.php” part?
  • #6 / Jul 23, 2009 4:48pm
    Manoj Thomas
    Hi giovanni, good point - that .htaccess snippet should work in removing ‘index.php’ from your URLs, but you’ll also need to edit your General Configuration (CP Home ›  Admin ›  System Preferences ›  General Configuration) and leave the Name of your site’s index page field empty.
    Hope that helps!
    Manoj
