blank page upon cp entry submit
July 02, 2009 2:51pm
Subscribe [4]
  • #1 / Jul 02, 2009 2:51pm
    bobh
    I’m moving between webhosts and have transplanted my db and files to a new server. Now when I hit submit or update an entry in the CP, I get a blank page. (The entry does get posted though.)
    I’ve looked around for similar problems and these are almost exclusive to memory issues. Earlier today I got some “fatal errors’ and had my host upgrade my memory limit to 64M, which got rid of the error but replaced it with a blank page.
    Then I read a comment advising to disable extensions alltogether. Doing this eliminates my blank screen issue but of course I need to use some extensions and when I re-enable them the problem returns.
    I’ve tried disabling my 3 extensions (fieldframe, accessible captcha & jquery for the cp) one by one but that did nothing.
    Who can help?
    I’m on EE 1.6.7 b20090515.
  • #2 / Jul 02, 2009 4:00pm
    So, just to recap: Your site works with 64MB if you disable all extensions, but breaks when you re-enable them? Have you turned on error reporting?
  • #3 / Jul 02, 2009 6:52pm
    bobh
    No, it only works when extensions are disabled.
    I applied the settings from the wiki entry but there’s still no sight of any errors.
  • #4 / Jul 03, 2009 2:08am
    bobh,
    Ask your host if they have disabled the PHP ‘display_errors’ directive and to to enable it if they have, or if the server allows scripts to override the setting.
  • #5 / Jul 03, 2009 4:06am
    bobh
    they have been set to ‘on’ the whole time.
  • #6 / Jul 04, 2009 10:36am
    bobh
    I ended up wiping the whole database and doing a clean install. Problem’s gone now.
  • #7 / Jul 04, 2009 11:04am
    Glad to hear it. Don’t hesitate to post again if needed.
