member_id in reverse_related_entries behaves like author id
June 17, 2009 8:22pm
  • #1 / Jun 17, 2009 8:22pm
    mogya
    In my understanding,
    {author_id} is the Member ID for the user who write the weblog entry
    And {member_id} is the Member ID for the currently logged-in user.
    they’re completely different parameter, aren’t they?
    However, in reverse_related_entries tag, it seems member_id behaves like author id.
    {exp:weblog:entries weblog="hogehoge" limit="1" disable="categories|category_fields|trackbacks"}
    {reverse_related_entries}
    <li>{entry_id}:{author_id}:{member_id}</li>
    {/reverse_related_entries }
    {/exp:weblog:entries weblog="magic_product" limit="1" }
    I got like this:
    21507💯1
    21508💯1
    21509:6:6
    Why the member_id is changed???
    Any way to get the currently logged-in user in reverse_related_entries?
    I’m using EE1.6.7 now.
  • #2 / Jun 17, 2009 8:25pm
    Greg Aker
    hum.  Off the top of my head, you could use the $SESS class to grab it.  Or have you tried:
    author_id="CURRENT_USER"
    -greg
    ETA:  There is also {logged_in_member_id} that you can try.
  • #3 / Jun 17, 2009 8:31pm
    mogya
    I’ve tried But it still shows same result..
    I’m afraid author_id doesn’t work in reverse_related_entries.
    > As Relationships are cached in order to reduce the load on ExpressionEngine, these are the only parameters available at this time.
    http://expressionengine.com/docs/modules/weblog/reverse_related_entries.html
  • #4 / Jun 17, 2009 8:33pm
    mogya
    O,o. I got working with {logged_in_member_id}.
    Thank you Greg. But why {member_id} doesn’t work? bug?
  • #5 / Jun 18, 2009 2:50am
    mogya,
    Glad you got it working. Checking with dev team as to why your first method did not work. Can I just confirm with you that your closing weblog entries tag does not look like this
  • #6 / Jun 18, 2009 3:03am
    mogya
    John,
    Yes. That’s my simple mistake. Sorry.
    Even using this,
    {/reverse_related_entries}
    {/exp:weblog:entries}
    Still I can’t get corret member_id.
  • #7 / Jun 18, 2009 3:07am
    mogya,
    that’s fine. I just wanted to confirm it. I will report back with what I find out for you.
