Single Entry Page q's
June 07, 2009 8:08am
  • #1 / Jun 07, 2009 8:08am
    Denidorm
    Expression Engine is new for me, so forgive me my ‘noobish’ questions.
    First, I’ve built my website on a template.
    My problem is: how do I edit the template of the Single Entries?
    I have a blog, and it would be handy to be able to change the page of the separate blogposts. Another thing, maybe related: only my main page is visible on Google. How can I add my different posts to Google?
    Now the posts are visible on Google, only when the posts are on the front page. That way I’m missing a lot of traffic.
    Thx in advance
  • #2 / Jun 08, 2009 8:26am
    Denidorm
    Anyone?
  • #3 / Jun 08, 2009 10:02am
    Boyink!
    Hi…
    You can usually figure out what template is being used by looking at your URL’s:
    <a href="http://www.yoursitehere.com/index.php/template_group/template/url_title/">http://www.yoursitehere.com/index.php/template_group/template/url_title/</a>
    I’m guessing the template is called “comments” or “detail”.
    If the site is new it could be that Google just hasn’t caught up fully yet.  I’ve had sites that take a couple of months to be fully indexed.  If your single-entries are obviously linked from your index page there’s really nothing more you need do.
  • #4 / Jun 08, 2009 2:03pm
    Denidorm
    Thanks for the reply.
    My url’s look like this:
    http://mysite.be/index.php/site/some_post_random_name/
    site is just the name of the template group… So I guess that means he bases the template for an individual post on the index page. If that is the case, how can I change that?
  • #5 / Jun 08, 2009 2:07pm
    Boyink!
    OK - so it looks like the index template is being re-used.
    Can you post the code from that template?
    There’s a couple of possibilities for how to change this, but it depends on how that template has been coded.
  • #6 / Jun 08, 2009 4:04pm
    Denidorm
    Well, I just used one of the templates of expressionengine.
    Code from the template:
    {assign_variable:my_weblog="my_blog"}
    {assign_variable:my_template_group="site"}
    <link rel='stylesheet' type='text/css' media='all' href='{stylesheet={my_template_group}/site_css}' />
    <style type='text/css' media='screen'>@import "{stylesheet={my_template_group}/site_css}";</style>
    <link rel="alternate" type="application/rss+xml" title="RSS" href="{path={my_template_group}/rss_2.0}" />
    <link rel="alternate" type="application/atom+xml" title="Atom" href="{path={my_template_group}/atom}" />
    <link rel="shortcut icon" href="afbeeldingen/favicon.ico"/>
    </head>
    <body>
    <div id="content">
    <div id="heaters">
    </div>
    <div id="blog">
    <div id="niettehoog">
    {exp:weblog:category_heading weblog="{my_weblog}"}
                                            <h2>{category_name}</h2>
    <p>{if category_description}<br />
    {category_description}<br />
    {/if}<br />
    {/exp:weblog:category_heading}</p>
    <p>    <br />
                                            {exp:weblog:entries weblog="{my_weblog}" orderby="date" sort="desc" limit="15" track_views="one" disable="member_data|trackbacks"}</p>
    <p><div class="entry"><br />
        <br />
                                            {date_heading}<br />
     <br />
    <h3 class="date">{entry_date format=' %l, %F %d, %Y '}</h3><br />
                                            {/date_heading}<br />
                                            </p>
    <p><h2 class="title">{title}</h2><br />
    {summary}</p>
    <p>{body}</p>
    <p><div class="posted">Posted by <a href="http://{profile_path=member/index}">{author}</a> on {entry_date format='%m/%d'} at {entry_date format='%h:%i %A'}</p>
    <p><br />
                                            {categories}</p>
    <p><a href="http://{path=site_index}">{category_name}</a> •<br />
                                            {/categories}</p>
    <p>{if allow_comments}<br />
                                            ({comment_total}) <a href="http://{url_title_path=">Comments</a> •<br />
    {/if}<br />
                                 <br />
    <a href="http://{title_permalink={my_template_group}/index}">Permalink</a>  </p>
    <p><br />
    </div><br />
    </div></p>
    <p><br />
    {paginate}<br />
    Page {current_page} of {total_pages} pages {pagination_links}<br />
    {/paginate}<br />
    {/exp:weblog:entries}</p>
    <p></div>
    I cut a bit here and there….
  • #7 / Jun 09, 2009 6:15pm
    Denidorm
    help! 😉
  • #8 / Jun 09, 2009 8:38pm
    Boyink!
    Sorry…got swamped with client work.
    This looks pretty straightforward which is good.
    Essentially what you need to do is create another template - call it detail, comments etc that will serve as the single-entry template.  You can copy this one as a starting point.  Once the single-entry template is in place all the links on this index template will need to be updated to point to the single-entry template.
    Will change to
    <a href="http://{title_permalink={my_template_group}/comments}">Permalink</a>
    Etc.
  • #9 / Jun 10, 2009 5:44am
    Denidorm
    Thank you very much, this did the trick (and pretty stupid of me not to see, it’s logic).
    Thank you!
  • #10 / Jun 10, 2009 10:29am
    Boyink!
    Not a problem - glad it worked out.
