This question is related to resolved thread.
I’ve been going back and forth with GoDaddy to get Expression Engine to work. The last response I got from them is the following:
To have everything happen the way you are wanting to do it you will need to upgrade to PHP 5.x. Directions on changing this was provided to you in the previous email. Also, yes ORIG_PATH_INFO is supported. For further customization you can create a php5.ini file (once using PHP5.x on the hosting account) and code it correctly and upload it to the hosting account. For more information about that file, use the search engine of your choice.
I went ahead and switched to PHP 5. I have updated the links to use the path variable and the links are still not working.
Any help would be appreciated. Thanks!
