random activation emails
May 21, 2009 9:25am
  • #1 / May 21, 2009 9:25am
    yolise
    For some reason I’m frequently getting emails bouncing to my email account, but I’m not sure where they are coming from. Here’s the header:
    This message was created automatically by mail delivery software.
    A message that you sent could not be delivered to one or more of
    its recipients. The following addresses failed:
      <[email protected]>
    domain name system error:
    domain jetfix.ee:
    domain not found
    --- The header of the original message is following. ---
    Received: from infong299.kundenserver.de (infong299.kundenserver.de [212.227.109.142])
        by mrelayeu.kundenserver.de (node=mreu0) with ESMTP (Nemesis)
        id 0MKuxg-1M76xQ3LcQ-00016Q; Thu, 21 May 2009 14:01:08 +0200
    Received: from 93.190.142.78 (IP may be forged by CGI script)
        by infong299.kundenserver.de with HTTP
        id 4AgDxV-1M76xQ1xyl-0003xv; Thu, 21 May 2009 14:01:08 +0200
    X-Sender-Info: <[email protected]>
    Precedence: bulk
    To: .(JavaScript must be enabled to view this email address)
    Subject: Enclosed is your activation code
    User-Agent: ExpressionEngine 1.6.4
    Date: Thu, 21 May 2009 14:01:08 +0200
    Reply-To: "[email protected]" <[email protected]>
    X-Sender: .(JavaScript must be enabled to view this email address)
    X-Mailer: ExpressionEngine 1.6.4
    X-Priority: 3 (Normal)
    Message-ID: <[email protected]>
    Mime-Version: 1.0
    Content-Type: text/plain; charset=utf-8
    Content-Transfer-Encoding: 8bit
    X-Provags-ID: V01U2FsdGVkX18e9Ax4nowzKqvM8OcpvHq3iQef1YVT8tw+hjK
     Nz2ut0AziiZ4xWT98mE1A0C3QQcEymb194774MR7aPf56R4bMe
     TSancak8Y8=
    The problem is that I don’t have anything set up that requires an activation code. I’m also not running 1.6.4 but rather 1.6.1 (which has long since expired, of course, or I’d upgrade).
    What could be generating these emails?
  • #2 / May 21, 2009 10:59am
    Do you have any other EE installs?
  • #3 / May 21, 2009 11:02am
    yolise
    Not on that server, and not using that email address. Most of the sites I’ve set up don’t tend to use the member registration systems at all - I use EE as CMS only for the most part.
  • #4 / May 21, 2009 11:05am
    I’m suspecting some sort of phishing, I get a few of those myself from time to time.. I’m going to check with the Dev team to see if that might be the issue. Thanks in advance for your patience.
