Hello all,
I’am using Expression engine 1.6.7 build 20090515.
Now we have some very strange behavior http://packed2.thisconnect.com/about_packed/category/mission/ this wont show the banner image on top.
The banner image is a different weblog then the text below so it uses dynamic=“off”. But still it shows no entry or doesn’t parse the ee tags. Now when i would do http://packed2.thisconnect.com/about_packed/category/mission/x it just works fine.
I really dont understand whats going on.
I have the same problem on a other page here its not parsing the date fields but the other data : http://packed2.thisconnect.com/news/category/actual/ if you would do http://packed2.thisconnect.com/news/category/actual/x it just works fine (showing the date).
Other extensions / modules i’ve used:
- Freeform
- Field frame
- Ngen file upload
- Tag
Thank you for any help!
Kevin
